Gas Water Heater
Old 08-12-02, 07:41 PM
JELLOBUNNY
Question Gas Water Heater
I was needing a little "getting started" help on replacing a bad T/P relief valve. I have already puchased the valve and Teflon tape. I cut off gas and cold water inlet. Drain valve is open. Is it safe just to start un screwing the old relief valve- Thanks for your assistance
Old 08-13-02, 05:04 PM
notuboo's Avatar
Pull trip lever, no water pressure with drain open....unscrew away....
