Dryer Temp Control
Old 09-01-02, 04:00 PM
racir23
GE gas dryer overheat, scorches
I there a way to check thermostats to know if the open at the right temp to shut down the burner. Thanks
Old 09-01-02, 04:37 PM
McDiver
I use to repair gas appliances while working for a gas utility. We were trained to put a high temp. thermometer in the exhaust hose. As long as the temp. did not reach over 160 F degrees the thermostat was fine.
Hope this helps,
McDiver
Old 09-01-02, 06:18 PM
A
Hey,
You can put as high temp probe in the same location as the thermostat.Put a voltage testers leads across the thermostat and as soon as you have voltage the thermostat has opened.
The limit on the thermostat should be marked on it.
Old 09-02-02, 05:06 AM
jeff1
Cool
Hi all,
A copy from Brewer...
**You can put as high temp probe in the same location as the thermostat.Put a voltage testers leads across the thermostat and as soon as you have voltage the thermostat has opened.
The limit on the thermostat should be marked on it.**
An example:
Some common "how to Identify" the thermostat for replacement. Part # identification.
Example: LS3-135
"L" Limit - opens on the rise in temp
"S" Switch
"3" Number of terminals
"135" Opening temperature
jeff.
