gas furnace problem
gas furnace problem
I have an Amana furnace that is about 7 years old. Last winter it started acting up a little. It would light then go out then relight and stay lit. Now that cold weather has set in again I turned the heat back on and now it won't stay lit for more than a few seconds at a time. The ignition system seems to be working fine but the burners won't stay lit. The furnace is equipped with a diagnostice baord that explains a flashing L.E.D. The L.E.D. flashes one time after powering it up. The explanation says "lock out and check furnace". Thanks for any help.
Received 7 Upvotes
Hello: Dallas 52
Chances are the pilot flame sensor is dirty and or defective. Carefully use a piece of sanding paper or steel wool and gently clean the elements surface.
Be sure to actual pilot flame is burning HOT and directly contacting the flame sensor element. An all blue flame is required. If there is any visable signs of YELLOW to the flame, air blow the entire pilot assembly to clearout and dust or lint.
Also check the pilot flame sensors electrical connections. Clean as required to insure a good connection. Both of these 2 steps should or could correct the problem. If not, it's possible the part is defective and needs replacing.
Another possibility could be the power exhaust fan not operating or there is a restriction in the venting system. Venting system also includes the vent cap on the flue pipe on the roof.
Suggestions:
Read the manufacturers online web site for product information, problem possibilities, causes and solving methods, part locations, disassembly, reassembly methods, repair proceedures and instructions, pictorials and schematics, which may be available online.
Other professionals replying within this forum, may have alternate solutions, suggestions, opinions and or test and repair methods. Check back several times.
VIP INFO:
Read the RECENT postings within this forum about this subject and the replies offered. Doing so will provide additional information regarding this type of problem and provide alternate solutions.
Good Luck
Forum Moderator
TCB4U2B2B Company Enterprises.
Fast, Fair, Friendly & Highly Proficient.....
Energy Conservation Consultants & Natural Gas Appliance Diagnostics Technician.
Suggestions:
VIP INFO:
Good Luck
Forum Moderator
Received 7 Upvotes
HAPPY CAMPER....:)
We LOVE To Hear Success Stories!...
Hello dallas52
On behalf of myself and anyone else who contributes helpful advice in my "Gas Appliances" forum, I'd like to express thanks to you for taking your valuable time to reply back in the forum.
Glad you were able to use my suggested method on the part, had successful results correcting the problem. Thanks for including the correctional method in your reply too.
I guess we can consider you to be another "HAPPY" camper...
Regards and Thanks
Gas Appliances Forum Moderator
Tom_Bart.....TCB4U2B2B Enterprises
Energy Conservation Consultant & Natural Gas Appliance Diagnostics Technician.
Hello dallas52
Regards and Thanks
