replacing gas stovetop ignitor
Old 11-07-02, 07:07 AM
lisaleso
Question replacing gas stovetop ignitor
Hello, our Caloric Prestige Series gas stovetop right front ignitor is cracked. I got a new ignitor from the local appliance part store and now need information on how to remove the old one and install the new one...any help you can provide would be great.
Thank you
lisa leso
Old 11-07-02, 03:23 PM
jeff1
Cool
Hi,
Model#?? Approx age??
Then we should know what style you have
jeff.
Old 11-07-02, 04:54 PM
lisaleso
reply..caloric ignitor issue
Hello jeff...
The model number is RST399UL. The ignitor p/n is : 0309358 and the serial # is 9205226065. With regards to the age...I couldn't tell you..I just purchased this house two mos ago and the Caloric double oven/gas stove was included...Unfortunately this one burner has a cracked ignitor and won't light...
Thank you for your help.
Lisa
Old 11-07-02, 05:16 PM
jeff1
Cool
Hi,
A pic that may help you....
http://www.partselect.com/Schematics/Maytag/AM9142.gif
These (0309358) are easy to change
Usually no need to turn off gas....usually good to remove power....lift off cast iron burner grate & burner cover/top....remove the star screw from the burner bottom....lift straight up on the burner...the burner bottom and electrode/ignitor will come off together....remove wire from ignitor ( it will pull off ) and you will have a speed clip holding the ignitor to the burner. Slowly pry off the speed clip with a flat screwdriver and change the ignitor....push the speed clip back on and reverse you other steps.
jeff.
