gas stove
Old 11-20-02, 06:14 PM
frank01
Question gas stove
Having a problem with the broiler, pilot light is lit, but when i turn the oven control knob to broil, it takes a while to light or doesn't light at all.....I need to know if there is a cleaning solution or a fix-it solution? Help
Old 11-20-02, 07:56 PM
Sharp Advice's Avatar
Admin Emeritus
Received 7 Upvotes on 6 Posts
Hello frank01. Welcome to my Gas Appliances topic & our Do-It-Yourself Web Site.
I suspect from the problem description there a two burners. One for the oven and a seperate one for the broiler. If this is correct, the pilot assembly is one of two common types.
If the pilot flame is horizontal with the safety element just above the pilots flame, the system is a flame switch safety. With this type of pilot assembly and safety element, often times simply cleaning the horizontal pilot assembly corrects the problem.
To accomplish this cleaning, simply blow out the flames, use a pipe cleaner, yes, a pipe smokers pipe cleaning cleaner, and clean off the entire surface were the flames come out of. Relite the pilot when completed and the broiler should resume working.
If not, the safety element just above the pilots flame will most likely need to be replaced. The type of safety is called a flame switch safety.
A falme switch safety can be identified because the opposite end of the element is round. About the size of a quarter and has two tiny screws attaching it to the wall of the oven or brioler.
Use caution if your appliance uses this type of safety element. The element is operated by house current. Behind the round attaching device is two wires.
Both wires supplied with household electrical current. Be sure to turn off the power if the appliances uses this type of safety device.
If this is not the safety system type used in your broiler, then it's a fluid safety device. This type the constant iplot enlarges or lites a second pilot flame. The second pilot flame heats a safety element {bulb} device. This element part may be defective.
In either safety device system, there is always the possibility the gas valve is defective. Be sure all the controls are set correctly prior to assuming a part or parts are defective.
For additional information etc. read the recent postings within this forum pertaining to stove topics. The questions already asked describe like or similarly related problem descriptions as your question.
These prior postings and any or all the replies offered within them contain almost all the required information needed pertaining to the many potential and or possible problems with the stoves unit like your describing.
Additional Suggestions:
Read the manufacturers online web site for product information, problem possibilities, causes and solving methods, part locations, disassembly, reassembly methods, repair procedures and instructions, pictorials and schematics, all or part of which may be available online.
An excellent source for orginal replacement parts is your local retail appliance parts store. Bring the make, model and serial numbers. The info will help to determine the possible problem causes.
Appliance part stores test and carry replacement parts for almost every brand. The locations for the dealers, agents and retail part stores are listed in the phone book.
To save time, search this form for stove problems. In doing so you're bound to find the same or similar problem asked. The reply or replies contained within the question will be all of the possbile solutions.
If you need further assistance, use the REPLY button to add any additional information or ask additional questions after attempting the correctional method or methods offered.
Regards & Good Luck, Forum Host & Multiple Topic Moderator.
TCB4U2B2B Company Enterprises. Energy Conservation Consultant & Gas Appliance Diagnostics Technician.
