Oven Door Problem
Old 11-27-02, 02:44 PM
James Ward
Gas Kitchen Stove
The oven door will not close. If I try to force it it still will not close.
Old 11-27-02, 04:22 PM
Sharp Advice's Avatar
Admin Emeritus
Received 7 Upvotes on 6 Posts
Hello: James
If there isn't objects in the jams and the hindges are not loose or damaged, very possible the brackets are damaged in side the the cabinet frame.
If the oven is a built in oven only appliance, the cabinet will have to be removed from the wall to access the hindges, springs and brackets.
If the stove {range} is a free standing unit, the parts can be accessed thru the oven or broiler side panels, etc.
Recently posted a reply to another question on this topic. Check the reply in that topic for additional information too.
Regards & Good Luck. Web Site Host & Multiple Topic Moderator.
TCB4U2B2B Company Enterprises.Gas Appliances Forum Moderator Energy Conservation Consultant & Natural Gas Appliance Diagnostics Technician.
