Water Heater Problems
Old 12-09-02, 09:00 AM
Bman8950
Water heater pilot light???
This is an update from an earlier post, but a different forum. Had a problem with the pilot light on my Rheem hot water heater going out immediately after installing a new hot water line for a bath. Basically, everytime I lit the pilot, it would stay lit, the burners would fire up fine, but then as soon as it reached the proper temp., the burners would turn off and so would the pilot. Changed the thermocouple and it worked fine for a day, but now it's doing the same thing. Air in gas line, not enough air for combustion? Running out of answers, any ideas????
B-Man
Old 12-10-02, 06:59 AM
Sharp Advice's Avatar
Admin Emeritus
Received 7 Upvotes on 6 Posts
Hello: B-Man
Water heater pilot outages as explained in your question is not a result of adding an additional hot water line or air in the gas line.
More likely to be associated with the thermocouple. The position upwards of the thermocouple in the pilot assembly. Only the tip of the t-couple is to be heated by the pilots flame.
Also check the threaded end of the t-couple tightness into the magneto. Slightly tight or snug but not firmly tight. Check the cleanliness of the magnetos threaded inlet and the head of the t-couple plus it's threads. No thread compound on the threads etc.
Depending on the type of water heater, there could be any other number of possible problems. Check this forum for additional information on water heater problems.
Retail parts dealers can also help determine what the possible problem may be. Bring the make, model and serial numbers if you stop in at the store.
Use the search engine to locate all the topics on this type of
do-it-yourself task. The search engine is the button on the very top of this page in the blue section to the right.
If you need further assistance, use the REPLY button to add any
additional information or questions, etc. Using this method also moves the topic back up to the top of the list automatically.
Regards & Good Luck.
Gas Appliances Forum Moderator Moderator.
Web Site Host & Multiple Topics Moderator.
Tom_Bart......Company Enterprises.....TCB4U2B2B
Energy Conservation Consultant & Natural Gas Appliance Diagnostics Technician.
Old 12-10-02, 01:18 PM
Bman8950
ok now.
Thanx Tom. Checked everything you said and also cleaned out the grill on the louvered door which was full of dust. Whatever I did, it seems to have helped because it's working fine now. Hope it stays that way.
B-Man
Old 12-11-02, 06:09 AM
Admin Emeritus
Hello: B-Man
Glad you had sucess resolving this problem, posted back the final results and included what you did to solve the problem.
Cleaning the air openings in the louvered door was most likely the proper method. Doing so reveals there importance to proper air flow into the firebox.
Proper air flow into the firebox not only supplies air for combustion but also determines burner flame characterics.
Both intake air flow and air volume are vital to proper operations.
