Dryer Noise Problem
Old 01-06-03, 03:50 PM
duro
whirlpool gas dryer
dryer is making noise almost as if something is out of balance
Old 01-06-03, 07:50 PM
jeff1
Cool
Hi,
You can read about some common noise trouble makers (drum support wheels, belt idler pulley, ect ) from the page below....
http://www.applianceaid.com/whirlpool-dryers.html#noises
jeff.
Old 01-06-03, 08:20 PM
Sharp Advice's Avatar
Admin Emeritus
Received 7 Upvotes on 6 Posts
Hello duro. Welcome to my Gas Appliances forum and our Do-It-Yourself Web Site.
Noise is a common problem when the drum rollers wear out on some models. Some dryers do not use rollers. Instead they use pads called gliders or sliders. Some dryers use both rollers and glider or slider pads in combination.
The noise may not be coming from only one worn out part. Therefore, I suggest you open up the dryers cabinet and remove the front panel. Look for signs of worn out parts mentioned above.
What the noise indicates is those parts have become wornout and the drum is rotating on the support bracket and not on the intended parts. To correct the condition, it will be necessary to replace any and all worn parts.
In order to accomplish this task, the dryers top and front panel will need to be removed. Attached to the front panel will be the drums support bracket. On most models the slider or glider pads will be located on the top of the support bracket.
Basically, what needs to be done is a replacement of all the rotating parts or parts that the drum rotates on and the belt also while the dryer is opened up and under repairs.
I highly suggest you clean out all lint inside the cabinet and clean out the entire exhaust system, while in the repair process.
Write down the make, model and serial numbers and visit the local appliance retail parts store in or near your home. There you will find the needed replacement parts and helpful information.
Squealing noises may come from worn out motor bearings, a worn out belt or pulleys, fan blower cage, etc.
Regarding the belts positioning over, under and/or around the pulleys, my best suggestion is to make a hand drawing of the locations and positions prior to removing the old belt.
Refer to the drawing when installing the new replacement belt to be positive it is correctly positioned on the drum and routed on the pulleys. Then store that drawing within the dryers rear removable panel for future use.
While your attempting this do-it-yourself project, a few words of caution and suggestions may be in order.
Be sure to turn off the gas supply first. Unplug the appliance.
Web Site Picture:
http://www.applianceaid.com/images/l...ler-pulley.jpg
Appliance parts dealers carry replacement parts for all appliances and are listed in the phone book.
If you need further assistance, use the REPLY button to add any additional information or ask additional questions after attempting the correctional method or methods offered.
Regards & Good Luck, Forum Host & Multiple Topic Moderator.
TCB4U2B2B Company Enterprises. Energy Conservation Consultant & Gas Appliance Diagnostics Technician.
