dryer drum loose
Old 04-02-03, 11:15 AM
fosco
dryer drum loose
We installed a dryer maintainance kit, with new rollers,belt etc. and also replaced the rear drum seal.
The problem is that the drum falls foward leaving a gap at the top and back. approximately 5/16 wide.
All advice greatly appreciated.
Old 04-02-03, 08:20 PM
Sharp Advice's Avatar
Admin Emeritus
Received 7 Upvotes on 6 Posts
Question More Detailed Information Requested
Hello fosco. Welcome to my Gas Appliances forum and our Do-It-Yourself Web Site.
Not sure what may be causing the problem and where you mean what falls "foward leaving a gap at the top and back"
My assumption is the drum. If that is the case, the drum is not supported correctly in the front lower half. The drum is supported by a front support on the back inside of the door panel.
Kindly provide more detailed information about the exact problem with the dryer. In depth and detailed information regarding the problem helps to explain the situation your dealing with in a manner that allows myself and or other professionals to offer the best possible helpful solutions, suggestions and professional advice.
Any and all additional detailed information you can provide may help to expose a clue regarding the current problem and help to determine the exact repair to correct the condition.
Your assistance in this matter would be appreciated and beneficial.
To add more information, please use the REPLY button. By doing so, the additional information you add will remain within this posting {Thread} and allow the forum readers to follow the topic.
Suggestions:
Read the manufacturers online web site for product information, problem solving methods, disassembly, reassembly methods, repair proceedures and instructions, pictorials and schematics, which may be available online.
Retail parts dealers can also help determine what the possible problem may be. Bring the make, model and serial numbers if you stop in at the store.
Check the other questions within this forum, for other additional information on your topic, specific dryers problem or conditions and read the replies offered. Chances are the condition and or problem has already been covered in complete detail.
If you need further assistance, use the REPLY button to add any additional information or ask additional questions. Doing so will automatically keep your question at the top of the forum list.
Regards & Good Luck. TCB4U2B2B.....Company Enterprises
Tom_Bartco. Doityourself Web Stie Host & Gas Appliances Forum Moderator. Energy Conservation Consultant & Natural Gas Appliance Diagnostics Technician.
Old 04-03-03, 11:59 AM
fosco
We have reviewed the installation procedures and we believe we have done everything correctly.
The drum appears to be resting properly on the front support and rear rollers.
When the drum is held up square to the the rear bulkhead, there is a small gap between the front of the drum and the front seal around the inside diameter of the drum. (approx. 1/8 ).
Also, it seems there is too much movement
from front to back, as if the drum is too short.
We can not get the drum to fit snugly to the rear bulkhead and be supported sufficiently in the front. The front seal seems fine.
When rotating the drum, it rotates eccentricly.
Here are URLs to photos of the inside of the drum, showing the problem-
http://www.gigglezonegreetings.com/dryercloseup.jpg
http://www.gigglezonegreetings.com/dryercloseup2.jpg
http://www.gigglezonegreetings.com/dryer.jpg
Here you can see it fits fine at the bottom of the drum, the gap is at the top-
http://www.gigglezonegreetings.com/dryerbottom.jpg
We used a dryer maintainence kit that was for all 29" dryers, it wasn't specific to our brand (KitchenAid), could the non-OEM parts be the problem?
