Gas Mains
Old 06-03-03, 01:14 PM
B
changes to gas mains - slightly O.T.
when the utility replaces a gas main, or installs a side leg to serve a new house, they manage to do the work without (usually) disrupting service. i know that the main is under only a few inches of pressure, but still, a lot of gas would escape; and the downstream homes would be gas-starved for at least several minutes; and the new line/main would be getting a mix of air and gas in the line until it was purged.. SO, how do they do it?
Old 06-03-03, 03:12 PM
Sharp Advice's Avatar
Admin Emeritus
Received 7 Upvotes on 6 Posts
Hello: Bruce
Good question.
The simple answer is dual feed system.
The line in the street has about 30-35 pounds of pressure and is feed {supplied} from both sides. All gas mains are dual feed lines.
If the street supply pipe where not dual sided suppled, the problem you invision would result.
Old 06-04-03, 06:06 AM
B
great answer, and makes sense. it reminds me of British in-house electric distribution - complete loops back to the breaker panel, rather than our system of straight runs.
