Go Back  DoItYourself.com Community Forums > Household Cleaning, Kitchen Appliance Service and Repairs > >Gas< Kitchen Appliances, Dryers and BBQ's
Reload this Page >
*No Heating Appliances, Fireplace and/or Water Heater Questions* (Updated 02-09)
Old 06-11-03, 10:51 AM
Sharp Advice's Avatar
Admin Emeritus
Received 7 Upvotes on 6 Posts
Thumbs down *No Heating Appliances, Fireplace and/or Water Heater Questions* (Updated 02-09)
Note to all forum topic users and readers:
Asking questions which pertain to natural gas water heaters, gas fireplaces, fireplace gas log sets, furnaces and/or room and and/or living environment area heaters would be best answered in the forum topic which specifically deals with the appliance.
Although my Gas Appliances forum welcomes questions on natural gas appliances, I do not suggest posting questions on the appliances mentioned above in this forum topic.
Plumbing, Air & Heat Forum:
Plumbing, Heating, Cooling, A/C, Fireplaces, Air Filtering & Water Conditioning Systems - DoItYourself.com Community Forums
Boilers - Steam & Hot Water Systems:
Boilers - Steam and Hot Water Systems - DoItYourself.com Community Forums
This topic covers Radiators & Baseboard Heating
Gas & Oil Heating Furnaces:
Gas and Oil Home Heating Furnaces - DoItYourself.com Community Forums
This topic covers Forced Warm Air Furnaces With Registers - Natural Gas, Propane Gas, and Fuel Oil Heating Systems
Heat Pumps & Electric Heating:
Heat Pumps and Electric Heating - DoItYourself.com Community Forums
This topic covers Forced Warm Air, Electric, Radiant & Portable Heating
Water Heaters:
Water Heaters - DoItYourself.com Community Forums
This topic covers Natural & Propane Gas, Oil, Electric, Solar, and Tank-less
Fireplaces, Gas Logs and Chimneys:
Fireplaces, Heating Stoves, Flues and Chimneys - DoItYourself.com Community Forums
Home, Workshop, Utility, Patio, Garage and Portable Heaters:
This topic covers all Natural Gas and Propane Heaters. Floor Furnaces, Vertical Wall and Suspended Heaters. Gravity Furnaces, Shop, Garage, Patio and All Portable Utility Heaters.
As a means of offering you a quicker method for obtaining helpful information with questions, I suggest you do a "Search" within the existing forum questions. Key words are an important aspect to searching. Use the keyword search method to best obtain answers.
Existing questions already asked that are like or similar to the problems with the appliance you have, will contain almost every possible & potential solution to the most common problems often associated to these appliances.
Knowing the exact problem description and searching using the key words of other topics on the appliance in question and searching using those key words will help to locate the postings quickly.
Additional Suggestions:
Read the manufacturers online web sites for product information, problem possibilities, solving methods, part & assembly locations, disassembly, reassembly, proper repair methods & procedures to follow, pictorials, schematics, etc. which may be provided online.
As it pertains to appliances, an excellent source for original replacement parts is your local retail appliance parts store. Retail parts dealers can also help determine what the possible problem(s) may be.
Bring the make, model and serial numbers. The information will help to determine the possible problem causes. Parts dealers are listed in the phone book under appliances.
Kindly be sure to select the correct forum topic based upon the type of heating system you have.
HEATING FORUM TOPICS:
HEAT PUMPS & ELECTRIC HEATING:
BOILERS - STEAM & HOT WATER SYSTEMS:
GAS & OIL HEATING FURNACES:
Our resident moderator heating and or water heater professionals can provide the helpful information, suggestions, repair methods and advice needed. Kindly read existing questions in those forums, before asking your question. Doing so will help you more quickly resolve the problem you are having with your heating appliance or water heater.
Should you need further assistance after posting your original question and/or after attempting any repair solutions offered, please do not post another new question on the same appliance. Always use the REPLY button.
Using the REPLY button keeps all threads together, automatically moves the question back up the daily list of questions for easy reading & following along for everyone else concerned.
When posting any new question, in the subject line, type in as few words as possible. Avoid brand names in the subject line. Ask your question, supplying all the details, brand name, model type, serial numbers, fuel type, problem descriptions, recent repairs, parts replacements, etc within the "Text" body of the message only. Not in the title. Doing so helps to clearly identify the problem in the title which aids in searching within the forums topic.
Your assistance in these matters will be very much appreciated.
Additional Helpful Do-It-Yourself Links:
DIY Help Links:
http://links.doityourself.com/
http://links.doityourself.com/links/appliances/
STOVES-RANGES-OVENS-BROILERS
For additional helpful information:
Range/Stove/Oven/Broiler Info, Leak Detection, Fault Codes, Fuel Conversion & Links - DoItYourself.com Community Forums. Reading this thread will provide information on how to diagnose and fix some problems.
WATER HEATER HELP LINK:
Water Heater Draining, Flushing Information, Water Leak Detection, Help Pages & Links - DoItYourself.com Community Forums
GAS DRYER HELP LINK:
>Dryer Information + *Fuel Conversion*< Info Contained Here< - DoItYourself.com Community Forums
TANK-LESS WATER HEATER HELP LINK:
>>>FYI: Tankless Water Heater Information With Links IncludedDryer Information + *Fuel Conversion*< Info Contained Here< - DoItYourself.com Community Forums
Reminder:
If you need further assistance with any question or need to update any post you made, use the reply button to add any additional information or ask additional questions on the same appliance. Doing so will automatically move or keep your question at the top of the forums list of questions.
DRYER SERVICE TIP:
It's always advisable to clean the entire exhaust venting system every 2 years. Or during any dryer maintenance, connection and or repairs.
Always consider the warranties and future service needs for any major appliances your considering to purchase. Price isn't always the best guide for long term appliance investments.
Regards & Good Luck. Sharp Advice.
TCB4U2B2B Business Management Services. Web Site Host, Forums Monitor, Gas Appliances Topic Moderator & Multiple Forums Moderator. Energy Conservation Consultant & Natural Gas Appliance Diagnostics Technician.
Manufacturers Web Sites:
Sears Appliance Home Pages:
Craftsman Tools, Fitness Equipment, Kenmore Appliances, Lawn & Garden - Sears.com
Parts & Accessories | Shop & Find Lawn & Garden, Appliance Parts at Sears PartsDirect | SearsPartsDirect.com
Whirlpool's Home Web Site: (Also makes appliances for Sears)
http://www.whirlpool.com
Maytag Appliance Home Page:
http://www.maytag.com
Maytag 1-800-688-9900 USA
Maytag 1-800-688-2002 Canada
Maytag is also the maker of Amana, Jenn-Air, Magic Chef and Caloric Appliances.
Maytag Appliance Help Forum Thread:
http://forum.doityourself.com/showthread.php?t=153846
General Electric Appliance Home Page:
GE : imagination at work
Whirlpool Appliance Home Page:
Jen Air Appliance Home Page:
Jenn-Air
Amana Appliance Home Page:
Amana: Kitchen Appliances and Laundry Appliances from Amana
Bosch Appliance Home Page:
Bosch Home Appliances - Dishwashers, Washers, Dryers, Ovens, Ranges, Microwaves, Cooktops, Ventilation, Refrigerators, Small Appliances, Warming Drawers
Roper Appliance Home Page:
http://www.roperappliances.com
Kitchenaid Appliance Home Page:
KitchenAidŽ: Welcome to KitchenAid.com
Miele Appliance Home Page:
http://www.miele.co.
Electrolux Appliance Home Page:
Welcome to Electrolux USA
Frigidaire Appliance Home Page:
http://www.frigidare.com
Staber Appliance Home Page:
Energy Efficient Washing Machines, Dryers, and Laundry Detergent by Staber Industries
Appliance Parts, Pictures & Help:
Appliance Parts From PartSelect | Repair Parts For Major Appliances
Appliances Parts & Help:
Appliance Parts, Repair Help and Service Referral
Kitchen Appliance Parts:
http://www.parts-depot.online.com
DIY'S Gas Appliances, Parts, Installation Supplies and More:
http://doityourself.com/store/plumbing.htm
DIY'S Gas Appliances Pages:
Ranges, Stoves, Ovens and Appliance Tips.
Oven and Stove | DoItYourself.com
DIY'S Gas and Oil Heating Pages:
Oil and Gas Heating Furnaces | DoItYourself.com
DIY'S Water Heating Pages:
Water Heaters | DoItYourself.com
DIY'S Small Appliances Pages:
Other Kitchen Appliances | DoItYourself.com
