Stove burner ignition
Old 07-30-03, 09:36 AM
Tuan
Was stove won't ignite
My gas stove has 4 section. Only the 2 left one will ignite when I turn it on to cook. But the 2 right one wont ignite, I have to turn it on and use a match to light it up. Can you give me adive of how to fix it, and what part?
Thank you
Tuan
Old 07-30-03, 10:09 AM
Sharp Advice's Avatar
Admin Emeritus
Received 7 Upvotes on 6 Posts
Hello: Tuan
If the source is a sparking ignitor, the sparker may be dirty or defective. If the ignitor is a pilot flame, the flame may be out. Also possible the ignition ports are plugged up.
The ignition ports will be located on the side of the burner. Cleaning all the ports is required to allow burner ignition.
In some cases, the entire burner has to be removed to complete this task successfully.
Read the prior topics, within this forum, on this subject of stove burner ignition and the replies offered. Prior postings and any or all the replies offered within them contain almost all the required information needed pertaining to the many potential and or possible problems with an oven.
If you need further assistance or care to post the results of this repair, use the REPLY button. Doing so moves the topic to the top of the daily list automatically.
Regards & Good Luck. TCB4U2B2B Company Enterprises.
Tom_B. Gas Appliances Forum Moderator.
Energy Conservation Consultant & Natural Gas Appliance Diagnostics Technician.
Old 07-31-03, 09:55 AM
Tuan
Thank you very much Mr. Shape Adive, I will give it a try.
Tuan
