Water Heater Ignition Problem
Old 09-22-03, 05:34 AM
cstew32
Water Heater lights intermittently
I have a RUUD model PVP50-1. It is about 9-10 years old. One day it did not relight. We turned it off for a minute or two and then turned it back on (we used the black on/off button inside the service door). It lit and worked fine for several days then the same situation had to be repeated. It always lights after turning off, but now it seems to be happening more often. When lit I did note that the flame is for the most part blue, but it does get streaked with an occassional orange burst. Any suggestions?
Thanks!
Old 09-22-03, 06:30 AM
Sharp Advice's Avatar
Admin Emeritus
Received 7 Upvotes on 6 Posts
Hello cstew32. Welcome to my Gas Appliances forum.
Very possible the pilot flame is restricted with lint, dust and or some other type of debris. Turn the pilot off. Use a can of computer keyboard compressed air to blow out the pilot assembly.
The pilots flame must be all blue in color & in direct contact with the thermocouple. Once you have established all this, allow time to note if the same condition exists.
If so, the thermocouple may need to be replaced. A thermocouple is the part the pilot flame touchs and keeps hot. The end containing the element bulb is inside the water heaters firebox. Be sure the control knob is turn off prior to removing the two covers to access the inside of the firebox.
Follow the very thin tube outwards until you locate where it is connected. It will be screwed into the bottom of the main control valve. This location is usually just to the left side of the larger diameter center aluminum burner gas tube.
On some water heaters the burner assembly must be completely removed from the inside of the burner compartment to remove the element end of the thermocouple from it's holding assembly.
The end of the thermocouple has a male threaded end. This end must be carefully unscrewed out of the control housing using a small open ended wrench.
A thermocouple is generic except for it's length. Thermocouples are made in different lengths. Measure the removed part or take the one you remove to any hardware store and replace it with an exact duplicate in length. The parts cost is very nominal.
New thermocouple packages will contain complete do-it-yourself installation instructions and pictures. The package also contains additional clips of various assortments.
Not all the parts contained in the package with the thermocouple will be needed. The packages contain an assortment of holding parts and clips that are generic and designed to fit a wide variety of water heaters applications.
Once you have installed the replacement thermocouple, turn the control to the 'PILOT' position. Relite the pilot in the normal manner. Replace the inner fireboxes metal cover.
Next rotate the control knob to the 'ON" position. The burner flames should lite up and resume heating the tanks water to the preset desired thermostats temperature.
If the burner doesn't light up immediately, the water in the tank may already be hot enough. To verify this, rotate the temperature knob to a higher setting to test it. The burner flames should now lite up and resume heating the tanks water.
If you had to remove the entire burner assembly, soap test the two tubing nut fittings to the right of the thermocouple fitting while the burner is ON. If there are any leaks, tighten the hex head fittings carefully and as needed, to stop any visable leaks, as indicated by the soap bubbles.
HINTS & TIPS:
DO NOT use any pipe tape on any of the hex head nut fittings.
DO NOT use a wrench to start the male tubing nuts or the threaded end of the thermocouple.
HAND start the threads to avoid cross threading and damaging the threads. Once your sure the threads are correctly prestarted and tightened as much as possible using fingers only, use a wrench to further tighten the nut but do it carefully. DO NOT overtighten the nuts. Just firmly secured.
Disclaimer:
The information above is offered to provide basic information and instructional procedures only. Methods and procedures apply only to tank type water heaters.
Results and methods may vary. Always read your owners manual and closely follow the advice and procedures given in the manufacturers booklet, owners manual or on the labels attached to the tank and or parts packages. Always follow all safety warnings!
Suggestions:
Read the manufacturers online web site for product information, problem possibilities, causes and solving methods, part locations, disassembly, reassembly methods, repair procedures and instructions, pictorials and schematics, which may be available online.
An excellent source for orginal replacement parts is your local retail appliance parts store. Appliance parts dealers test and carry replacement parts for all appliances. Parts dealers are listed in the phone book under appliances.
Retail parts dealers can also help determine what the possible problem may be. Bring the make, model and serial numbers if you stop in at the store. The info will help to determine the exact parts used in the model assembly line run and possible problem causes.
Appliance Repair, Care and Installation Tips:
Web Help Link: http://doityourself.com/appliance/index.htm
If you need further assistance, use the REPLY button to add any additional information or questions, etc. Using this method also moves the topic back up to the top of the list automatically.
Read the already asked questions, within this forum, on this topic of water heaters and the replies offered. In them you'll find additional information.
Regards & Good Luck. Web Site Host, Forums Admin & Gas Appliances Forum Moderator. Energy Conservation Consultant & Natural Gas Appliance Diagnostics Technician.
