Gas Dryer stops prematurely
Old 10-07-03, 09:32 AM
Joe Lusso
After about 40 minites on the regular (low heat) setting the dryer stops & you must wait about 30 minites for it to cool down enough to reset . I have already made sure the exhaust paths are clear .
Old 10-07-03, 08:34 PM
Sharp Advice's Avatar
Admin Emeritus
Received 7 Upvotes on 6 Posts
Hello Joe. Welcome to my Gas Appliances topic and our Do-It-Yourself Web Site.
If the dryer stops running always at exactly 40 minutes and does not restart when you attempt to do so as you normally do, it is possible the motor is overheating. When that happens, the high temp turns the motor off until it cools down.
If the dryer does this stopping at random times, it is possible the door safety cutoff switch is defective and or the door is not fully closing to keep the switches button fully depressed.
Another possiblity is the timer. Test it by using another temperature setting and or cycle out of the low heat setting. If the dryer works correctly, the low heat section of the timer may be defective.
If the dryer has optional selection switches, anyone of those may also effect that cycle and or be causing the problem.
Help Links:
Appliance Repair, Care and Installation Tips:
DIY Web Help Link: http://doityourself.com/appliance/index.htm
The Appliance Information Site
www.Appliance411.com
http://www.repairclinic.com
http://www.fixitnow.com
http://www.american-appliance.com/service
Retail appliance parts dealers can also help determine what the most likely possible problem may be. Take will need the make, model and serial numbers.
Appliance parts dealers are an excellent source for original replacement parts and problem resolving matters. Dealers are listed in the phone book under appliances.
Be sure the electrical power to the appliance is turned off, before attempting any repairs. Always check for gas leaks whenever a repair includes any connection of a gas part.
Read the existing questions on the subject of dryers. Doing so will quickly provide you with answers to questions & provide additional information on how to resolve the problem.
If you need further assistance, use the REPLY button to add any additional information or ask additional questions. Doing so will automatically keep your question at the top of the forum list.
Regards & Good Luck. Sharp Advice
TCB4U2B2B Company Enterprises.
Web Site Host, Gas Appliances Topic Moderator & Multiple Forums Moderator. Energy Conservation Consultant & Natural Gas Appliance Diagnostics Technician.
Personal Reminder:
Buckle Up & Drive Safely.
"The Life You Save, May Be Your Own."
