gas dryer temp adj.
Old 10-13-03, 07:58 AM
MaddMick601
gas dryer temp adj.
hello all. New member here, so I don't know if this has been covered before. For a Kenmore gas dryer,stock # 87475820, is there any way to adjust the drying temperature? I got this appliance used, and it seems very hot. It actually melted the bottom of the lint trap. Let me know what you think, and thanks for the help!
Old 10-13-03, 09:27 PM
Sharp Advice's Avatar
Admin Emeritus
Received 7 Upvotes on 6 Posts
Hello MaddMick601. Welcome to my Gas Appliances topic and our Do-It-Yourself Web Site.
Temperature is controlled by sensors. They are usually located by the blower fan. Usually attached to the fan housing case and or frame.
The sensors look like parts about the size of a quarter. The are installed in an oval plate with attachment ends. The sensor is in the middle. There will be two wires attached to them.
Usually two of these. They are not adjustable. Only replaceable.
Retail appliance parts dealers can also help determine what the most likely possible problem may be. They will need the make, model and serial numbers.
Appliance parts dealers are an excellent source for original replacement parts and problem resolving matters. Dealers are listed in the phone book under appliances.
Be sure the electrical power to the appliance is turned off, before attempting any repairs.
Thermostats and Sensor Information:
http://diy.appliance411.com/parts/sh...r-thermo.shtml
http://www.repairclinic.com
http://www.fixitnow.com
http://www.american-appliance.com/service
Read the existing questions on the subject of dryers. Doing so will quickly provide you with answers to questions & provide additional information on how to resolve the problem.
If you need further assistance, use the REPLY button to add any additional information or ask additional questions. Doing so will automatically move your question to the top of the forums list of questions.
Regards & Good Luck. Sharp Advice
TCB4U2B2B Company Enterprises.
Web Site Host, Gas Appliances Topic Moderator & Multiple Forums Moderator. Energy Conservation Consultant & Natural Gas Appliance Diagnostics Technician.
Personal Reminder:
Buckle Up & Drive Safely.
"The Life You Save, May Be Your Own."
DRYER SERVICE TIP:
It's always adviseable to clean the entire exhaust venting system every 2 years. Or during any dryer maintenance, connection and or repairs.
