Caloric Oven igniter won't turn off while oven is used
Old 11-27-04, 02:24 PM
caloricman2004
Hi,
I have an older model Caloric gas stove that had been working fine until recently when we needed it for an after funeral gathering. The oven turned on and cooked well enought BUT the problem is the IGNITER wouldn't turn off. During the entire heating process the clicking noise just kept going and going and going. (The top burners still ignite as normal) Any help out there?
Thanks!
Manny
xxxxxx@mail.com
Forum Monitors Note:
This post has been edited.
E-mail address only removed.
Kindly use the forum topics only, to exchange information.
Email contact addresses are not allowed in the forum topics.
Web Site Host & Forums Monitor.
Old 11-28-04, 03:33 PM
Sharp Advice's Avatar
Admin Emeritus
Received 7 Upvotes on 6 Posts
Hello Manny. Welcome to my Gas Appliances topic and our Do-It-Yourself Web Site.
The tiny rod element in the pilot assembly is the pilot flame sensor. Chances are the element is dirty and not able to gather enough heat from the pilot flame to signal back to the sparking module to turn module off.
Try this. Clean sensor end that would be in the pilot flame. Use fine grit sand paper and or steel wool. Clean gently and carefully. Only clean tiny amount off to expose clean surface. Retest. May resolve the problem and may not.
If the cleaning results prove successful, the results may not last long. If the cleaning does not help, element needs to be replaced.
Pilot flame must be all blue. No yellow. Yellow indiceates dusty pilot assembly. To clean pilot assembly, if needed, use a can of computer pressurized keyboard cleaner. Insert plastic extension tube into can. Insert other end of plastic tube end into all open areas of the assembly. Blow out all dusty. Retest and note the results.
Before attempting any repairs, be sure to unplug the appliance from the wall receptacle power source first.
Kindly use the reply button to add any additional information or ask additional questions after performing the above procedure(s).
Web Site Host, Forums Monitor, Gas Appliances Topic Moderator & Multiple Forums Moderator. Energy Conservation Consultant & Natural Gas Appliance Diagnostics Technician.
Personal Safety Reminder:
Buckle Up & Drive Safely.
"The Life You Save, May Be Your Own."
Range-Stove-Oven-Broiler Basic Help Information & Manufacturers Web Site Links: http://forum.doityourself.com/showthread.php?t=159808
Retail appliance parts dealers can also help determine what the possible problem may be. Bring the make, model and serial numbers. Appliance part stores and dealers are listed in the phone book.
