magic chief spark module
Old 12-04-04, 06:58 AM
mike repko
Cool magic chief spark module
hello i think i have narrowed it down to spark module have week spark at front two burners magic chief model 6498xrs with non hinge top how do i axcess the spark unit cant seem to find any instructions
Old 12-05-04, 10:59 AM
Sharp Advice's Avatar
Admin Emeritus
Received 7 Upvotes on 6 Posts
Hello Mike. Welcome to my Gas Appliances topic and the Do-It-Yourself Web Site.
If only the two front burners appear to be having a weak spark, not likely to be the module but possible. Cleaning the effected sparkers usually resolves the problem. As would the cleanliness and clearance (gap) between the sparking element and the grounding locating where the spark jumps to.
I would highly suggest you first insure the above two or checked and serviced before replacing the sparking module. Replacing the module may not be necessary and/or may not resolve the problem.
When cleaning, try a thin strip of fine grit sanding paper or stell wool. Be sure to clean the area of sand grit or steel wool well, once cleaning is done. Retest. May solve the problem or condition.
The sparkers themselves may be wornout. Replacement is than required. If all else fails, than and only than should the module be suspected.
Magic chef is a product of Maytag. The links and helpful info is on the web sites below:
Maytag Appliance Home Page:
http://www.maytag.com
Maytag 1-800-688-9900 USA
Maytag 1-800-688-2002 Canada
Maytag is also the maker of Amana, Jenn-Air, Magic Chef and Caloric Appliances.
Advertisers & Sponsors Web Sites:
Appliance Parts, Pictures & Help:
http://www.PartSelect.com
Appliances Parts & Help:
http://www.pcappliancerepair.com
Kitchen Appliance Parts:
http://www.parts-depot.online.com
Additional Help info which may apply:
Maytag Appliance Help Forum Thread:
http://forum.doityourself.com/showthread.php?t=153846
DIY Help Links:
http://links.doityourself.com/
http://links.doityourself.com/links/appliances/
Stoves-Ranges-Ovens-Broilers:
http://forum.doityourself.com/showth...hreadid=159808. Reading this thread will provide information on how to diagnose and fix some problems.
Additional Suggestions:
Read the manufacturers online web site for product information, problem possibilities, causes, solving methods, part locations, disassembly, reassembly methods, repair procedures, pictorials, schematics, downloadable repair and or owners manuals which may be available online.
Retail appliance parts dealers can also help determine what the possible problem may be also. They will need the make, model an serial numbers. Appliance parts dealers are an excellent source for original replacement parts. Dealers are listed in the phone book under appliances.
***Be sure the electrical power to the appliance is turned off, before attempting any repairs. Always check for gas leaks when ever a repair includes any connection of a gas part.
Kindly use the reply button to add any additional information and or questions. Any additional information you add will than remain within this posting. Using this method also moves or keeps your question at the top of the list automatically.
Sharp Advice. Web Site Host, Forums Monitor, Gas Appliances Topic Moderator & Multiple Forums Moderator. Energy Conservation Consultant & Natural Gas Appliance Diagnostics Technician.
Personal Reminder:
Buckle Up & Drive Safely.
"The Life You Save, May Be Your Own."
