Kenmore Stove (in wall)...Won't heat up!
Old 01-10-05, 10:41 AM
rookie796
Last week my Kenmore stove stopped heating up. It has a digital display and it usually starts at 100 degrees and goes up after 10min (normally) For some reason it will not heat up. The broiler will heat up, but not in the bake setting. My wife and I thought that may be the pilot light was out, but we can't find where this is....Can anyone help us?
Old 01-10-05, 07:11 PM
Sharp Advice's Avatar
Admin Emeritus
Received 7 Upvotes on 6 Posts
Hello rookie796 and Welcome to the Do It Yourself Web Site and my Gas Appliances topic.
Chances are the oven does not have a pilot light. It has a hot surface (glowing) ignitor (HSI) Check the broilers ignitor. You will likely see that one glowing when the broiler is turned on. If the one in the oven does not turn on and glow very brightly, it has to be replaced. Chances are it is burned out and not glow at all.
The above is based upon the fact that most ovens have a glowing ignitor. That oven may or may not. We have to assume it does soley because you mentioned digital display. Below is the web site link you'll need for additional information.
Sears Appliance Parts & Repair:
Sears Home Page:
http://www.sears.com
Sears Search By Model Number Page:
http://www3.sears.com
Whirlpool's Home Web Site: (Also makes appliances for Sears)
http://www.whirlpool.com
Stoves-Ranges-Ovens-Broilers:
Read This Post For additional helpful information:
http://forum.doityourself.com/showth...hreadid=159808.
Reading this thread will provide information on how to diagnose and fix some problems.
Reading the already asked questions in the topic will also be helpful. Retail parts dealers and appliances parts stores can also help determine what the possible problem may be based upon that specific brand and model. Bring the make, model and serial numbers. Dealers and appliances parts stores are listed in the phone book.
Additional Suggestions:
Read the manufacturers online web site for product information, problem possibilities, causes, solving methods, part locations, disassembly, reassembly methods, repair procedures, pictorials, schematics, repair and or owners manuals which may be available online.
Before attempting any repairs, be sure to unplug the appliance from the wall receptacle power source first.
Use the reply button to add additional information or questions. Using this method moves the topic back up to the top of the list automatically.
Web Site Host, Forums Monitor, Gas Appliances Topic Moderator & Multiple Forums Moderator. Energy Conservation Consultant & Natural Gas Appliance Diagnostics and Repair Technician.
Personal Safety Reminder:
Buckle Up & Drive Safely.
"The Life You Save, May Be Your Own."
