stuck cap
Old 02-03-05, 01:39 PM
sprinternate
stuck cap
the male cap is stuck at the end of our gas line and wont budge. is there something we can use or any tips to get it unstuck? it is for a gas dry hookup.
thanks
Old 02-03-05, 02:39 PM
Received 3 Upvotes on 3 Posts
Use a backup wrench. If you still can't remove it (highly unlikely) you may have turn off gas at meter and replace valve. If you are reluctant to do this you may want to call a dealer. SAFETY FIRST
Old 02-04-05, 09:23 AM
sprinternate
what is that, were can i get it, are they expensive?
Old 02-04-05, 11:57 AM
With all due respect I don't believe you should go any furhter with this project. A backup wrench is a second wrench used in the reverse position so in this case the valve doesn't move while taking off the cap. AND DON'T TURN OFF GAS METER
