Kenmore dryer not heating up but tumbling.
Old 02-03-05, 07:50 PM
RacerX
Hello to all,
I am having trouble with my kenmore dryer. It starts but it does not heat up. I have tried to search other posts to see what I should check. So here it goes. Just to let you know, I have no clue about dryer parts but I'm trying. Ok so here is what I checked.
1) I tried to make sure that all the lint was cleaned away.
2) I checked continuity at the thermal fuse. Seem to have continuity.
3) Next I checked to see if the ignitor glows. It does not glow
Now I do not know what to do. Should I order a ignitor? My wife wants this fix ASAP.
Thanks.
Old 02-07-05, 02:42 AM
Sharp Advice's Avatar
Admin Emeritus
Received 7 Upvotes on 6 Posts
Hello: RacerX
Most likely the hot surface ignitor is burned out. Replacing the ignitor with a new part will solve that problem. I personally would drive over to any local appliance parts store and buy the replacement ignitor cover the counter & in person.
Additional help can be found here:
http://forum.doityourself.com/showthread.php?t=159481
DIY'S Appliance Parts and Accessories Shopping Center.
http://doityourself.com/store/applianceparts.htm
Sears Appliance Parts & Repair:
Sears Home Page:
http://www.sears.com
Sears Search By Model Number Page:
http://www3.sears.com
Whirlpool's Home Web Site: (Also makes appliances for Sears)
http://www.whirlpool.com
Retail appliance parts dealers can also help determine what the most likely possible problem may be. They will need the make, model and serial numbers. Appliance parts dealers are an excellent source for original replacement parts and problem resolving matters. Dealers are listed in the phone book under appliances.
Be sure the electrical power to the appliance is turned off, before attempting any repairs. Always check for gas leaks whenever moving the appliance and/or a repair includes any connection of a gas part.
Web Site Host, Forums Monitor, Gas Appliances Topic Moderator & Multiple Forums Moderator. Energy Conservation Consultant & Natural Gas Appliance Diagnostics Technician.
Personal Safety Reminder:
Buckle Up & Drive Safely.
"The Life You Save, May Be Your Own."
DRYER SERVICE TIP:
It's always adviseable to clean the entire exhaust venting system every 2 years. Or during any dryer maintenance, connection, servicing and or repairs.
Old 02-19-05, 08:20 PM
pjlaird
not heating up
ours is not heating up either, did you finally find the problem.
thanks
