New frigidaire gas oven
Old 02-25-05, 07:16 PM
solyj
I just installed my new frigidaire gas oven model # FGF334BGWJ- The 4 burners on top ignite and work fine. When I turn the oven on the igniter turns bright orange but the oven broiler never lights. It is a brand new oven. Is there something I was supposed to open or release when installing it?
Thanks,
Sol
Old 02-26-05, 05:11 AM
Sharp Advice's Avatar
Admin Emeritus
Received 7 Upvotes on 6 Posts
Hello Sol and Welcome to the Do It Yourself Web Site and my Gas Appliances topic.
Generally speaking, the appliance is setup to operate without any need to turn open any valves or safety devices. Such may not be the case in this instance. I suspect the oven burner isolation valve may be turned off.
The valve will be a tiny one located on the gas supply to the ovens burner control. That supply tube will be coming off from the main inlet supply on the appliance. Trace back to the gas inlet from the oven burner control valve. Look for a tiny lever valve that will be inline from the gas source into the burner control valve. That shut off valve may be turned off.
STOVES- RANGES-OVENS-BROILERS
For additional helpful information:
http://forum.doityourself.com/showth...hreadid=159808. Reading this thread will provide information on how to diagnose and fix the problem.
Frigidaire Appliance Home Page:
http://www.frigidare.com
Frigidaire Search By Model Number:
http://www.frigidaire.com/manuals.asp
Use the reply button to add additional information or questions. Using this method moves the topic back up to the top of the list automatically.
Web Site Host, Forums Monitor, Gas Appliances Topic Moderator & Multiple Forums Moderator. Energy Conservation Consultant & Natural Gas Appliance Diagnostics and Repair Technician.
Personal Safety Reminder:
Buckle Up & Drive Safely.
"The Life You Save, May Be Your Own."
Old 02-26-05, 06:58 PM
Received 3 Upvotes on 3 Posts
Look for the appliance regulator where gas supply enters range. Many new applince regs have an isolation valve built into them (only controls oven). It may take a mirror to see the bottom of reg or just feel around. Look for a small lever .
