Ignitor won't Spark
Old 03-14-05, 06:25 AM
pcorad
Ignitor won't Spark
I've got an old oven/4 burner cooktop that came with the house I bought. It appears to be an ancient "Glenwood" model. I've called around, and none of the parts companies even recongnize the Model #.
When I first started using the cooktop, the 2 left burners ignited sporadically. Then they stopped sparking at all. I switched the ignitor wires where they plug into the plastic module in the back of the stove, and the now the left ignitors spark (and light), but right ignitor does not spark (will light with match).
So, it's pretty clear that the problem is not with the ignitors, but with the plastic module in the back, or something leading into the plastic module.
Thoughts on how to further troubleshoot??
Old 03-14-05, 08:40 PM
Received 1 Vote on 1 Post
Sounds like you did a pretty good job.
Old 03-24-05, 06:36 AM
pcorad
So, is there no other diagnostics I can run??
Old 03-24-05, 07:16 PM
Sharp Advice's Avatar
Admin Emeritus
Received 5 Votes on 4 Posts
Hello pcorad and Welcome to my Gas Appliances topic.
If the stove has a sparking module of any type or model, it can be replaced with either an OEM if available or a replacement of equal type. Not a part this is always specific to the brand appliance.
Remove the module and take it to the local appliance store with the stove brand name and model. The part can be replaced with most any generic part and work well.
Range-Stove-Oven-Broiler Basic Help Information, Fault Codes & Mfg's Web Site Links http://forum.doityourself.com/showthread.php?t=159808
Additional Suggestions:
Read the manufacturers online web site for product information, problem possibilities, causes, solving methods, part locations, disassembly, reassembly methods, repair procedures, pictorials, schematics, downloadable repair and or owners manuals, which may be available online.
Retail appliance parts dealers can also help determine what the possible problem may be also. They will need the make, model an serial numbers. Appliance parts dealers are an excellent source for original replacement parts. Dealers are listed in the phone book under appliances.
***Be sure the electrical power to the appliance is turned off, before attempting any repairs. Always check for gas leaks whenever the appliance is moved and/or a repair includes any connection of a gas part.
DIY Help Links:
http://links.doityourself.com/
http://links.doityourself.com/links/appliances/
Advertisers & Sponsors Web Sites:
Appliance Parts, Pictures & Help:
http://www.PartSelect.com
Appliances Parts & Help:
http://www.pcappliancerepair.com
Kitchen Appliance Parts:
http://www.parts-depot.online.com
Kindly use the reply button to add any additional information and or questions. Any additional information you add will than remain within this posting. Using this method also moves or keeps your question at the top of the list automatically.
Web Site Host, Forums Monitor, Gas Appliances Topic Moderator & Multiple Forums Moderator. Energy Conservation Consultant & Natural Gas Appliance Diagnostics and Repair Technician.
Personal Reminder:
Buckle Up & Drive Safely.
"The Life You Save, May Be Your Own."
Old 03-28-05, 06:11 AM
pcorad
Hi,
Thanks for the response. This is probably a very basic question, but I've looked at the links and have not found this answer: What is a module? Is it the plastic "box" that the ignitor wires, and all the other wires, plug into?
Old 03-28-05, 02:19 PM
Yes that's it
