Coverting Magic Chief Stove
Old 03-26-05, 02:03 PM
clydeman
I am installing a Magic Chief cook stove that came from a house with natural gas. We have LPG here, so I am needing to convert it. I have been told that I only need to adjust the air mixture, is this right? I know on a dryer I had to put in new gas jets.
Thank you
Old 03-26-05, 03:05 PM
Received 3 Upvotes on 3 Posts
NO that is not right. Depends on range-- you may need to replace burner orifices or just close them down. Also if equipped with regulator is it convertible to LP. I would not attempt this yourself. Call your local LP co and they will be able to convert for you. If you burn LP like it is now you may injure someone!!
