Kenmore gas range thermostat
Old 04-29-05, 02:08 PM
bradyv
I have a Kenmore gas range that I think needs a new thermostat. I took the range appart enough to get to the thermostat but there is one wire that goes to the back of the stove and then down in it. I am wondering if I should continue to disassemble to track this wire down to replace the part or is this job best left to a pro?
Old 04-29-05, 05:03 PM
Sharp Advice's Avatar
Admin Emeritus
Received 7 Upvotes on 6 Posts
Hello bradyv and Welcome to the Do It Yourself Web Site and my Gas Appliances topic.
That wire you're referring to is likely to be the heat sensing element which is known as a capillary (cap) tube. If it is, it's not a wire at all. It's a hollow metal tube filled with an inert gas.
That tube extends down into the ovens baking compartment. It must be carefully pulled out. The new tube must be very carefully reinstalled exactly as the existing one is installed. Be careful installing the new cap tube. It cannot be kinked or bent.
The only difference between yourself as a do it yourself person and a pro is, the pro replaced hundreds of thermostats. You can replace the thermostat yourself if you proceed slowly and carefully.
Just be sure the problem, whatever it is, is related to the thermostat and not some other part or cause. No problem description mentioned.
Sears Appliance Parts & Repair:
Sears Home Page:
http://www.sears.com
Sears Search By Model Number Page:
http://www3.sears.com
Whirlpool's Home Web Site: (Also makes appliances for Sears)
http://www.whirlpool.com
Retail appliance parts dealers can also help determine what the most likely possible problem may be. They will need the make, model and serial numbers. Appliance parts dealers are an excellent source for original replacement parts and problem resolving matters. Dealers are listed in the phone book under appliances.
Be sure the electrical power to the appliance is turned off, before attempting any repairs. Always check for gas leaks whenever moving the appliance and/or a repair includes any connection of a gas part.
Help Link: Range-Stove-Oven-Broiler Basic Help Information & Manufacturers Web Site Links: http://forum.doityourself.com/showthread.php?t=159808
Use the reply button to add additional information or questions. Using this method moves the topic back up to the top of the list automatically.
Web Site Host, Forums Monitor, Gas Appliances Topic Moderator & Multiple Forums Moderator & Natural Gas Appliance Diagnostics Technician.
Personal Safety Reminder:
Buckle Up & Drive Safely.
"The Life You Save, May Be Your Own."
