gas oven thermostat,control, regulator, etc.
there are around this country a few people who rebuild oven thermostats for antique gas ranges but none so far that I can find that are willing to help me learn how. can you help? I know it can be done and the parts must be out there somewhere because these guys get sometimes as much as $350 for one job. I do wood,coal stoves and want to branch out.
Hi:bobolink
Your correct. There are guys who can rebuild oven T-Stats.
If you have one that still works and the cap tube <the part that goes into the oven to sense the temperature> is not broken or damaged, remove the core located just below the temp knob. There will be two screws holding down a clip which holds the core in the valve body.
Once thats out, apply some lite grease and reassemble.
If you need parts, the trick is to call the T-Stat manufacturer and ask where parts may be obtained. <Even if you have to pay retail your still bucks ahead.>
Be advised that many unauthorized repair people do not buy wholesale. You have to build a repor with a dealer and ask for the wholesale price.
Plus you will need the machine to put the charge in any new cap tube you install.
Good Luck,
Tom
Sincerely,
TomBartco
TomBartco Enterprises.
Trade:Natural Gas Energy Consultant & Technician.
Appliance Service & Repairs Rep.
Vocations:Saw & Tool Sharpening. Small Engine Repairs.
Accurate Power Equipment Company.
E-Mail:TomBartco@doityourself.com
Personal Quote:
"Drive Safely. The Life You Save, May Be Your Own."
Good Luck,
Tom
Sincerely,
TomBartco
Personal Quote:
