Maytag gas dryer won't heat
Old 02-21-00, 05:20 PM
Guest
Post
I have a Maytag gas dryer, model D7500, approximately 6-7 years old. When you turn the dryer on it will ignite for a few seconds and then go out. The vent is clear and it worked fine this morning.
[This message has been edited by Cathi (edited February 21, 2000).]
Old 02-22-00, 05:35 AM
Guest
Post
Hi: Cathi
First most common problem for this symptom,
one of the controls on the front panel is in the wrong setting.
It was one one of the very easiest home service calls to do. Less then 5 minutes to make $45.00. Check the controls if not done already.
Second most common problem you already checked for, the restricted vent.
Most likely one of the solenoids on the gas valve has become defective.
Also a remote possiblity one of the contacts in the thermostat is burned out.
There are several other possiblities all related to controls, sensors or safety devices.
In my opinion, without the proper testing equipment, tools and knownledge, one would need to replace one part at a time until the correct one is found. Not a good solution.
Best bet is to contact the local service agency for your brand.
Sincerely,
TomBartco
TomBartco Enterprises.
Trade:Natural Gas Energy Consultant & Technician.
Appliance Service & Repairs Rep.
Vocations:Saw & Tool Sharpening. Small Engine Repairs.
Accurate Power Equipment Company.
Personal Quote:
"Drive Safely. The Life You Save, May Be Your Own."
