No Hot Water
Old 04-26-00, 08:16 AM
Guest
Angry
We are not getting any hotwater. Checked hot water heater is 40 gal gas. The pilot is lit. Water comes out lukework. The hot water heater is less than 2 years old. Any suggestions on what the problem may be.
Old 04-29-00, 05:36 AM
Guest
Post
Hi:KNMAC
With this limited amount of information, it will not be easy to determine the exact problem. I'll have to make a few assumptions here.
I take it you have been using this water heater for the last two years and this problem has just occurred and is a problem at every faucet.
If this is the case, check the thermostat setting. Someone may have lowered the temperature setting.
If this is a problem at only one faucet or shower valve and it's a mixit-valve <has one lever to adjust the temperature> I would suspect the cartridge is wornout and replace it.
Good Luck
Sincerely,
TomBartco
Trade:Natural Gas Energy Consultant & Technician.
Appliance Service & Repairs Rep.
Vocations:Saw & Tool Sharpening. Small Engine Repairs.
Accurate Power Equipment Company.
Personal Quote:
"Drive Safely. The Life You Save, May Be Your Own."
