GE Error code "F7" and beeps
Hi,
We have a GE JGRP17 gas oven that is flashing error F7 and beeping until power is removed. What does this code mean? Is there a easy way to reset this unit?, it is perfect condition, clean and well cared for. Is the possible repair expensive?
Thanks for all help. Greg
Hi:Greg
Off hand I can not tell you exactly what the error code means. However, check the settings mode and verify that there isn't two or more pre=programed timed settings causing the conflict.
Reset all functions back to manual. Then go from there.
All else fails:
Two options.
Read the owners manual.
Contact your local utility company.
Many utilities have a low or no cost in home service for appliances. Check with yours.
Good Luck.
P.S.
I will attempt to offer you more help.
But first I will need to contact one of my service reps and see if he/she can offer a solution.
All else fails:
Two options.
Good Luck.
P.S.
