mondern maid gas range
Old 08-08-00, 04:24 AM
Guest
Angry
replaced glow bar and valve only way to get oven to light is to tap on valve
Old 08-10-00, 01:57 PM
Guest
Lightbulb
Hi:mark neal
After doing all you have done, only things I can suggest you do is check for a loose connection, wires for continuity and replace the fuse.
On rare occasions, a bad fuse will absorb too much current. Tapping on the gas valve is a clue to low voltage.
Good Luck,
TomBartco
