GE gas dryer wont heat
I have this old (~ 10 years ?!?)GE gas dryer that won't heat up , no clicks but blowing cold air.Please help !
Model DDG9380VALWH
Serial MD310760G
Model DDG9380VALWH
Serial MD310760G
Hi:thm66
NO CLICKS? Rare. Double check this.
Often times only one click will be heard. No clicks is a good indication the timer may be defective.
Be sure the controls are set correctly. Set in air dry only will produce the no clicks.
You may have a gas valve with a defective primary solenoid causing this too.
Check the archives in this forum for instructions posted prior, regarding removal, testing and installation.
Good Luck,
TomBartco
Good Luck,
TomBartco
