Gas dryer not coming on
Old 08-10-00, 10:48 AM
Guest
Post
no power from dryer. check the start switch with meter seems ok...could it be the drive motor switch or the timer..
Old 08-10-00, 02:19 PM
Guest
Lightbulb
Hi:netnut
Yes. It could be the timer.
However, check the door safety switch.
If it's defective, the whole dryer becomes inoperate too.
If need be, unplug the dryer, bypass the switch by connecting the two leads together, <rap the well with electrical tape> and see if the dryer turns on.
If so, replace that safety switch.
Good Luck,
TomBartco
Old 08-10-00, 02:43 PM
Guest
Post
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by TomBartco:
Hi:netnut
If need be, unplug the dryer, bypass the switch by connecting the two leads together, &lt;rap the well with electrical tape&gt; and see if the dryer turns on.
Good Luck,
TomBartco
<HR></BLOCKQUOTE>
thanks Tom...i was able to track it down to a broken bracket for the door safety switch...good job
