Kenmore Gas Oven will not Ignite.
Old 08-16-05, 06:00 AM
dhunch
I have a Kenmore Gas Oven model 665.75824001, My igniter is bad in it, I know this because after messing with the spark igniter I got it to work, but I am afraid that it was only a temporary fix. My question is that the Oven bake burner tube assembly with spark igniter are sold together. How do I replace this and is there any thing special I should know about the process.
Old 08-17-05, 05:54 PM
Sharp Advice's Avatar
Admin Emeritus
Received 7 Upvotes on 6 Posts
Hello dhunch and Welcome to the Do It Yourself Web Site and my Gas Appliances topic.
I am not all that familar with a burner tube with a non removeable hot surface ignitor (HSI) or spark ignitor. However, if this is the case, unplug the appliance and remove the assembly.
Burner tube will be attached to the back wall inside the oven. The front of the burner tube secured to the front panel lip below the door inside. The wires to the HSI will have a quick disconnect at the end of them.
Take the entire assembly to any local appliance parts sote in your area. Bring the make, model and serial numbers to be sure you get an exact duplicate of the assembly or needed parts. Reassemble as found.
Sears Kenmore Appliance Parts & Repair:
Sears Home Page:
http://www.sears.com
Sears Kenmore Search By Model Number Page:
http://www3.sears.com
Help Link: Range-Stove-Oven-Broiler Basic Help Information & Manufacturers Web Site Links: http://forum.doityourself.com/showthread.php?t=159808
Use the reply button to add additional information or questions. Using this method moves the topic back up to the top of the list automatically.
Web Site Host, Forums Monitor, Gas Appliances Topic Moderator & Multiple Forums Moderator & Natural Gas Appliance Diagnostics Technician.
Personal Safety Reminder:
Buckle Up & Drive Safely.
"The Life You Save, May Be Your Own."
Old 08-18-05, 04:54 AM
dhunch
Problem Solved.
Thank you for your advice. It was that easy, just two screws and lift assembly out and place new one in. Thanks again.
