Kenmore dryer moisture sensor
Old 10-17-05, 12:23 AM
ghamilton's Avatar
I have a kenmore gas dryer # 110.87467810.In the auto dry mode, it does not get the clothes dry. I checked the vent, it is clear. I think it is the moisture sensor. The sears parts website has a listing for a SENSOR, RADIANT p/n 338906. Is this the same sensor? They have 1 in stock close to home. Thanks
Old 10-18-05, 06:13 AM
Sharp Advice's Avatar
Admin Emeritus
Received 7 Upvotes on 6 Posts
Greetings ghamilton. Welcome to the Gas Appliances forum topic.
If not dry means not fully dry and there is some heat inside the dryer, than the sensor may in fact be defective. Or the flame sensor can be defective, the solenoids (on top of the gas control valve) can be defective, timer defective, etc. Varies based upon what is meant by your description of "does not get the clothes dry."
Additional Suggestions:
Read the manufacturers online web site for product information, problem possibilities, causes, solving methods, part locations, disassembly, reassembly methods, repair procedures, pictorials, schematics, downloadable repair and or owners manuals, which may be available online.
Retail appliance parts dealers can also help determine what the possible problem may be also. They will need the make, model an serial numbers. Appliance parts dealers are an excellent source for original replacement parts. Dealers are listed in the phone book under appliances.
Gas Dryer Help Link:
this post
Sears Appliance Parts & Repair:
Sears Home Page:
http://www.sears.com
Sears Search By Model Number Page:
http://www3.sears.com
Whirlpool's Home Web Site: (Also makes appliances for Sears)
http://www.whirlpool.com
***Be sure the electrical power to the appliance is turned off, before attempting any repairs. Always check for gas leaks whenever the appliance is moved and/or a repair includes any connection of a gas part.
Kindly use the reply button to add any additional information and or questions. Any additional information you add will than remain within this posting. Using this method also moves or keeps your question at the top of the list automatically.
Web Site Host, Forums Monitor, Gas Appliances Topic Moderator & Multiple Forums Moderator. Energy Conservation Consultant & Natural Gas Appliance Diagnostics and Repair Technician.
Personal Reminder:
Buckle Up & Drive Safely.
"The Life You Save, May Be Your Own."
