Maytag dryer [front panel removal]
Old 10-20-05, 12:16 PM
B
How do you remove the front panel of the Maytag mdg6000? I can't find a parts diagram that shows what holds it to the cabinet.
Old 10-20-05, 12:54 PM
majakdragon's Avatar
Received 1 Upvote on 1 Post
beepa, Welcome to the DIY Forums.
Look at the bottom lip of the front of the dryer. There should be 2 screws. Remove them and pull out on the bottom and it will disengage the clips at the top of the dryer. Remove wires from the door switch and you can set the panel aside. Be sure to DISCONNECT POWER before doing any work on the unit. Good luck.
