Gas Dryer Connecters
Old 11-13-05, 11:53 AM
T
Im having a problem with my new gas dryer, Im connecting as per the old one (ie. 3/8" (I think) coil supply directly to the dryer), and there is a very slight leak where the soap is bubbling up a little bit so we can't use it until this is sorted. The supply is also off (fyi).
The leak is coming from the back of the nut which is being connected to the dryer. I have looked on the instructions on the coil feeder pipe and it states not to connect straight to the dryer.
What do I need to do? Buy a gas valve to connect in between the coil pipe and the dryer, or is my coil pipe just faulty? Im using the gas teflon tape also which has helped a little but not much.
Thanks
Old 11-13-05, 02:12 PM
T
Its ok, it was to do with the flare part missing. All done. Thanks for the replies.....??!
Old 11-13-05, 05:40 PM
Sharp Advice's Avatar
Admin Emeritus
Received 5 Upvotes on 4 Posts
Hello tobja and Welcome to the Do It Yourself Web Site and my Gas Appliances topic.
Glad you found and fixed the problem.
Happy Thanksgiving
Web Site Host, Forums Monitor, Web Sites Moderator Hiring Agent, Gas Appliances Topic Moderator & Multiple Forums Moderator & Natural Gas Appliance Diagnostics Technician.
Personal Safety Reminder:
Buckle Up & Drive Safely.
"The Life You Save, May Be Your Own."
