Caloric Gas Range/Timer Issue
Old 12-21-05, 09:53 AM
chazerae119
Our Caloric gas range started automatically setting off the timer when the oven got hot. Now the timer beeper runs continuously when the range is plugged in. Is there a way to pull the timer fuse??? We don't really need the timer, but with the stove unplugged, none of the electric ignitors work, so if we could get rid of the constant beep, we would be alright until we can replace the range. Thanks!
Old 12-21-05, 08:27 PM
Sharp Advice's Avatar
Admin Emeritus
Received 7 Upvotes on 6 Posts
Hello chazerae119 and Welcome to the Do It Yourself Web Site and my Gas Appliances topic.
Depending upon the age of the appliance and the model, you may be able to disconnect the clock timer. Unplug the stove. Access the timer and look for a quick disconnect wire terminal on the clock. Pull it off the clock and be sure it's wires will not come into contact with anything metal.
Doing this may cause some other functions and or operations to not work depending on the specific model and how it is wired. May be worth a try.
I doubt the link below will provide any help.
However, the phone number may. Call Maytags service number.
Maytag Appliance Home Page:
http://www.maytag.com
Maytag 1-800-688-9900 USA
Maytag 1-800-688-2002 Canada
Maytag is also the maker of Amana, Jenn-Air, Magic Chef and Caloric Appliances.
Help Link: Range-Stove-Oven-Broiler Basic Help Information & Manufacturers Web Sites:http://forum.doityourself.com/showthread.php?t=159808
Post back the results. Use the reply button to add additional information, the results or additional questions. Using this method keeps or moves the topic back up to the top of the list automatically.
Retail parts dealers and appliances parts stores can also help determine what the possible problem may be based upon that specific brand and model. Bring the make, model and serial numbers. Dealers and appliances parts stores are listed in the phone book.
Web Site Host, Forums Monitor, Web Sites Moderator Hiring Agent, Gas Appliances Topic Moderator & Multiple Forums Moderator & Natural Gas Appliance Diagnostics Technician.
Personal Driving Safety Reminder: Buckle Up & Drive Safely.
"The Life You Save,May Be Your Own."
Old 12-24-05, 09:42 AM
chazerae119
It worked!!!
Thanks so much, that worked!!! We took the plate off the back and there were 3 wires, a green, a black and a white. The green wire is the ground wire and we had to leave that one connected, however, we disconnected the black and white and although we have no clock or timer, the electric ignition is back and we can use the oven again with no loud beeping!!!
Thanks again for your help :-)
Old 12-26-05, 09:17 AM
Admin Emeritus
Hello: chazerae119
Good job and glad the advice I offered solved that problem. Also, thanks for posting back the final results. Always good to know the advice offered worked and thanks again for taking the time to post back the results.... Be nice if more members did likewise....
