Converting Propane Dryer to Gas
We are moving from a house that has propane to one with natural gas. I didn't see how the dryer was initially converted to propane. Now I want to convert it back to gas. What needs to be done to make this coversion.
Thank you,
Brian
Thank you,
Brian
You need the original parts that were supplied with the dryer, pre-conversion. It consists of a burner orifice and a vent cap for the dryer's gas valve. If you don't have them, you need to contact the manufacturer for the parts.
Received 7 Upvotes
Hello Brian and Welcome to the Do It Yourself Web Site and my Gas Appliances topic.
Check with any local appliance parts store in your area. They can supply the orifice and advise you how to convert the appliance regulator. Most regulators only require the tower cap, on the gas control valve, be turned over and rescrewed back into the tower. All based upon the brand, model and serial number, which you will need to take with you.
If you are not comfortable with doing the work yourself, some parts stores will or may do the conversion for you for a small fee, if the gas control valve is brought into the store. Not all stores do this. You have to ask first.
The local gas utility, in some locals, also provide the conversion service free or for a modest fee. Ask them also.
More dryer conversion info in the sticky note above in the forum topic.
Dryer help info: http://forum.doityourself.com/showthread.php?t=159481
Be sure the electrical power to the appliance is turned off, before attempting any repairs or services. Always check for gas leaks whenever moving the appliance and/or a service or repair includes any connection of a gas part.
Use the reply button to add additional information or ask additional questions. Doing so will automatically move or keep your question to the top of the forums list of questions.
Regards & Good Luck. Web Site Host, Forums Monitor, Gas Appliances Topic Moderator & Multiple Forums Moderator. Natural Gas Appliance Diagnostics Technician.
Personal Driving Safety Reminder: Buckle Up & Drive Safely.
"The Life You Save, May Be Your Own."
DRYER SERVICE TIP:
It's always adviseable to clean the entire exhaust venting system every 2 years. Or during any dryer maintenance, connection, servicing and or repairs.
DRYER SERVICE TIP:
