kimbo
Old 01-09-06, 02:52 PM
G
kimbo
do i need to shut off the gas main just to attach an adapter for a gas dryer to the line inside the house. This is the first adapter being installed as it is a new home and one was not there.
Old 01-09-06, 03:17 PM
Received 3 Upvotes on 3 Posts
Is there a line valve inside at dryer location?? If yes control gas from there. If no control gas from meter..However if at meter you may want to call your gas co for asistance
Old 01-09-06, 04:57 PM
You will be better off calling in a professional.
What do you mean by "attach an adapter" what kind? What is it going to do?
The meter main belongs to the gas company if you turn it off you must check for leaks when you turn it back on. Also you may turn it on incorrectly and blow the diaframe in the regulator. Each appliance should have a shut off valve within 6 feet. =====[X]======{ }
