whirlpool gas dryer
Old 02-15-06, 09:58 AM
whirlpool gas dryer
hello i have a small problem i got this dryer second hand they told me it worked fine so i get it home but before i connect the gas i pluged it in to see if the igniter lit up no dice so i assumed that was the problem and while i was getting this part someone mentioned the thermel fuse so i grabed that to no dice now on this model does the gas have to be hooked up for the igniter to work
Old 02-15-06, 08:23 PM
Sharp Advice's Avatar
Admin Emeritus
Received 5 Votes on 4 Posts
Hello mrbandit. Welcome to my Gas Appliances topic and the Do-It-Yourself Web Site.
Gas does not need to be on. Hot surface glow ignitor will work with or without gas. If not gas is present, ignitor will still glow and attempt to ignite the gas, which is not there.
To help determine a cause for the problem, read a few of the existing question on dryers. Also the help sticky note here: http://forum.doityourself.com/showthread.php?t=159481
Additional Suggestions:
Read the manufacturers online web site for product information, problem possibilities, causes, solving methods, part locations, disassembly, reassembly methods, repair procedures, pictorials, schematics, downloadable repair and or owners manuals which may be available online.
Retail appliance parts dealers can also help determine what the most likely possible problem may be. They will need the make, model and serial numbers. Appliance parts dealers are an excellent source for original replacement parts and problem resolving matters. Dealers are listed in the phone book under appliances.
Whirlpool's Home Web Site: (Also makes appliances for Sears)
http://www.whirlpool.com
Advertisers & Sponsors Web Sites:
Appliance Parts, Pictures & Help:
http://www.PartSelect.com
Appliances Parts & Help:
http://www.pcappliancerepair.com
Appliances Parts:
http://www.RepairClinic.com
Kitchen Appliance Parts:
http://www.parts-depot.online.com
Whirlpool Appliance Parts: (with pictures & diagrams)
http://www.AppliancePartsPro.com
Be sure the electrical power to the appliance is turned off, before attempting any repairs or services. Always check for gas leaks whenever moving the appliance and/or a service or repair includes any connection of a gas part.
Use the reply button to add additional information or ask additional questions. Doing so will automatically move or keep your question to the top of the forums list of questions.
Regards & Good Luck. Web Site Host, Forums Monitor, Gas Appliances Topic Moderator & Multiple Forums Moderator. Natural Gas Appliance Diagnostics Technician.
Personal Driving Safety Reminder: Buckle Up & Drive Safely.
"The Life You Save, May Be Your Own."
DRYER SERVICE TIP:
It's always adviseable to clean the entire exhaust venting system every 2 years. Or during any dryer maintenance, connection, servicing and or repairs.
