ge spectra xl44 oven problem
Old 03-03-06, 08:16 PM
P
Question ge spectra xl44 oven problem
Hi My parents have a xl44 who's oven quit. Dad (86 y.o.) took it apart and found a broken ignitor, but is unsure if he broke it during disassembly. We replaced the ignitor, but it doesn't function.
I've been trying to find a manual, but havent' yet. We havent taken off the main back panel yet.
We took off the upper to, looking for a wiring diagram (not there). The broiler and stove top burners all function. I'm wondering if there is a fuse or circuit breaker for that burner. Any advice would be greatly appreciated, including a description of the relationship between the ignitor and the gas valve - is there a thermocouple function involved?
Thanks in advance, Anne
Old 03-04-06, 06:22 AM
Sharp Advice's Avatar
Admin Emeritus
Received 6 Upvotes on 5 Posts
Hello primordial_b and Welcome to the Do It Yourself Web Site and my Gas Appliances topic.
Some ovens do have a fuse and some do not. If there is one it will be located at the end of the electrical power cord where it enters the appliance. Be sure the power cord is removed before searching for it or removing the protected cover. No circuit breaker used in an oven but be sure there is electrical power to the oven.
If the igniter is broken it must be replaced. If the igniter has been replaced and does not turn on, that's yet another entire problem. We first have to establish where we are at the present time. Not sure. Is the igniter presently in the oven the new one or the old one? Is it broken? Yes or no?
The wiring diagram is likely located inside a back panel. May or may not help, if one is not familiar with reading them. Worth a try. The owners manual will not be helpful in this instance. Not thermocouples used in modern ovens with glow igniter's. (HSI) Hot Surface Igniter's.
Retail parts dealers and appliances parts stores can also help determine what the possible problem may be based upon that specific brand and model. Bring the make, model and serial numbers. Dealers and appliances parts stores are listed in the phone book.
Additional Suggestions:
Read the manufacturers online web site for product information, problem possibilities, causes, solving methods, part locations, disassembly, reassembly methods, repair procedures, pictorials, schematics, repair and or owners manuals which may be available online.
Cautionary Reminder Note:
Before attempting any repairs, be sure to unplug the appliance from the wall receptacle power source first.
Help Link: Range-Stove-Oven-Broiler Basic Help Information & Manufacturers Web Sites: http://forum.doityourself.com/showthread.php?t=159808
Advertisers & Sponsors Web Sites:
Appliance Parts, Pictures & Help:
http://www.PartSelect.com
Appliances Parts & Help:
http://www.pcappliancerepair.com
Appliances Parts:
http://www.RepairClinic.com
Kitchen Appliance Parts:
http://www.parts-depot.online.com
Use the reply button to add additional information or questions. Using the reply button keeps or moves the topic back up to the top of the list automatically.
Web Site Host, Forums Monitor, Web Sites Moderator Hiring Agent, Gas Appliances Topic Moderator, Multiple Forums Moderator & Natural Gas Appliance Diagnostics Technician.
Personal Driving Safety Reminder: Buckle Up & Drive Safely.
"The Life You Save, May Be Your Own."
Old 05-27-07, 04:47 PM
A
I also have the above mentioned range. We can not find the owners manual. My wife used the oven 1 hour ago, and it worked fine. She turned on the oven to preheat for some cookies, and it did not light up. The ignition coil works fine , but usually we can hear gas going into the oven an now we can not. The broiler will not light up either althought the burners on top of the range light fine.
Is there a reset switch or could the small hole that supplies the gas to the oven be plugged?
Very frustrating. Thank you,
AJ
