GE Gas range burner not lighting
Old 04-08-06, 10:21 AM
R
GE JGBP35BEA1, natural gas,8 years old. Have strong spark I can see it, have gas, have checked orifice. I'm baffled and another burner is not coming on about 50% of the time. I suspect not enough gas at initial turnon. Any thoughts?
Old 04-09-06, 04:59 AM
Sharp Advice's Avatar
Admin Emeritus
Received 7 Upvotes on 6 Posts
Arrow Restricted Ignition Ports
Hello redt. Welcome to my Gas Appliances topic and the Do-It-Yourself Web Site.
Chances are the ignition ports are restricted with debris from a prior spill over. The ports are the tiny holes going up the side of the burner. Small amount of gas comes out of them. Used to ignite the burn. Those tiny holes have to be cleaned out.
Cleaning can be accomplished using sewing straight pin needle. DO NOT enlarge the ignition holes. Doing so will have adverse burner lighting effects.
Burner heads where the flames will not burn completely around the entire circumference of the burner head, the holes which do not have flames are clogged up and need cleaning.
To clean the sparker's, use an old tooth brush or pipe cleaner. DO NOT attempt to bend any tabs if the sparker's have them. The part is very brittle and will crack the ceramic insulator and or the tip will break off.
Read the other questions pertaining to stove & range ignition problems within this forum. Doing so will provide additional information.
For additional helpful information:
http://forum.doityourself.com/showth...hreadid=159808. Reading this thread will provide information on how to diagnose and fix the problem.
Kindly use the reply button to post all replies, add additional information or ask additional questions when replies are posted. Using this method moves and/or keeps the topic back up to the top of the list of questions automatically and keeps all content on the same subject within one thread.
Web Site Host, Forums Monitor, Gas Appliances Topic Moderator & Multiple Forums Moderator. Energy Conservation Consultant & Natural Gas Appliance Diagnostics and Repair Technician.
Personal Driving Safety Reminder:
Buckle Up & Drive Safely. "The Life You Save, May Be Your Own."
Old 04-10-06, 04:03 PM
R
Have checked holes where gas comes to igniter. All clear. On this cooktop the burners can easily be moved to another postion. The one which won't light moved to the back lights every time. I'm stumped.
Old 04-10-06, 08:51 PM
Admin Emeritus
Hi: Redt
On the effected burner, close the air shutter slightly and retry. Usually resolves the problem if the ignition ports are cleared.
Old 04-12-06, 06:22 PM
R
I see no air shutter to adjust. Have adjusted these on other appliances.
