gas oven noise
Old 06-24-06, 01:47 PM
K
Question gas oven noise
magic chef gas oven recently began making a whirring or whoosing noise continously after not being used for several days. Does not appear to be the clock or timers. Don't smeel gas either. Any ideas?
Old 06-24-06, 05:25 PM
Sharp Advice's Avatar
Admin Emeritus
Received 7 Upvotes on 6 Posts
Welcome kkid1984 to my Gas Appliances forum and the Do-It-Yourself Web Site.
Vague problem description with little detailed information and several possible causes. Check venting system. Oven may not be venting properly. Remove any foil if any is used. Check air intake vents located around bottom of oven, etc. Be sure burner flames appear around entire burner. May be some clogged ports, etc.
More help here:
Help Link: Range-Stove-Oven-Broiler Basic Help Information & Manufacturers Web Sites: http://forum.doityourself.com/showthread.php?t=159808
Additional Suggestions:
Read the manufacturers on line web site for product information, problem possibilities, causes, solving methods, part locations, disassembly, reassembly methods, repair procedures, pictorials, schematics, repair and or owners manuals which may be available on line.
Cautionary Reminder Note:
Before attempting any repairs, be sure to unplug the appliance from the wall receptacle power source first.
Use the reply button to add additional information or questions. Using the reply button keeps or moves the topic back up to the top of the list automatically and keeps all communications on this subject in one thread.
Web Site Host, Moderator Hiring Agent, Gas Appliances Topic Moderator, Multiple Forums Moderator & Natural Gas Appliance Diagnostics Technician.
Personal Driving Safety Reminder: Buckle Up & Drive Safely.
"The Life You Save, May Be Your Own."
Old 06-25-06, 05:57 AM
K
sorry for vagueness, the sound is more like something running even though oven is not on. don't smell gas, but certainly concerned about that
Old 06-25-06, 07:43 PM
Admin Emeritus
Hello: kkid1984
So your saying there is a noise even though oven is not being used or on. HUMMM. Unplug the appliance and determine if the noise still exists or is gone. If noise still present, not the oven. Check for something else nearby. No noise. Problem is in the with the oven. What it may be I'm not sure.
Old 06-26-06, 05:08 PM
K
shut off power, noise ceases..is it possible self cleaning mode is stuck on some how and runs off electric
