Gas Oven intermittent lighting problem
Old 02-07-07, 07:53 PM
L
I have a GE gas range, model JGBS22BEAICT, 5 years old, with an electric igniter. The top burners work fine. The problem is that the oven does not always light. Sometimes it may take 3 to 4 minutes to come on and other times it works fine. There is a gas smell when it takes that long. A new igniter and gas valve were installed and that did not fix the problem. I can take a hand-held propane lighter, turn the oven knob on high and it will come on after 3 or 4 minutes, but the flame is very weak and goes out easily, leaving the gas on. It appears at times that the gas flow is too low for the igniter to light it. An appliance repairman and the gas company have checked it. Any ideas?
Old 02-08-07, 07:09 AM
Sharp Advice's Avatar
Admin Emeritus
Received 7 Upvotes on 6 Posts
Hello Landlord2 and Welcome to the Do It Yourself Web Site and to my Gas Appliances topic.
Likely a defective gas valve or a mis match between the two new parts, etc. You need to contact whom ever it was that fixed the appliance and installed the parts. They will need to re-diagnose the condition and replace any defective part.
Even though parts where new, does not insure they work as intended. An improper match between igniter and gas valve can also cause problems. Contact the rep agent.
Cautionary Reminder Note:
Before attempting any repairs, be sure to unplug the appliance from the wall receptacle power source first.
Read The Sticky Help Note In This Topic:
Range-Stove-Oven-Broiler Basic Help Information & Manufacturers Web Sites. http://forum.doityourself.com/showthread.php?t=159808
Or copy and paste the below link into your browsers address bar. http://forum.doityourself.com/showthread.php?t=159808
Use the reply button to add additional information or questions. Using the reply button keeps or moves the topic back up to the top of the list automatically and keeps all communications on this subject in one thread.
Web Site Host, Moderator Hiring Agent, Gas Appliances Topic Moderator, Multiple Forums Moderator & Natural Gas Appliance Diagnostics Technician.
Personal Driving Safety Reminder: Buckle Up & Drive Safely.
"The Life You Save, May Be Your Own."
