gas oven range works oven slow to heat
Old 04-13-07, 05:46 AM
Unhappy gas oven range works oven slow to heat
I have a maytag gas oven range. The stovetop works fine but when I turn on the oven it is slow to heat and there is a whooshing sound like it just ignited all of a sudden. Also there is a gas smell that permeated the home.
Moved the unit recently to clean behind and thought maybe could be not connected right but then wouldnt' the range not be working either. Unit is about 12 years old.
Thanks
Old 04-13-07, 06:32 AM
Sharp Advice's Avatar
Admin Emeritus
Received 7 Upvotes on 6 Posts
Hello j5walkers. Welcome to Gas Appliances topic and our Do-It-Yourself Web Site.
Check the area around the burner tube where the igniter is. Likely to see a white powdery residue. If so, clean the area. The powder is residue from the gas fuel used. A common occurrence.
The powder causes a delay of the burner to light up and other similar problems including a slight gas odor until the burner finally lights. And also check that each side of the burner lights and it has flames at every port/hole in the burner. If not, those without flames indicate the holes/ports/slots are clogged up too. Burner needs cleaning.
Cautionary Reminder Note:
Before attempting any repairs, be sure to unplug the appliance from the wall receptacle power source first.
Read The Sticky Help Note In This Topic:
Range-Stove-Oven-Broiler Basic Help Information & Manufacturers Web Sites. http://forum.doityourself.com/showthread.php?t=159808
Or copy and paste the below link into your browsers address bar. http://forum.doityourself.com/showthread.php?t=159808
Use the reply button to add additional information or questions. Using the reply button keeps or moves the topic back up to the top of the list automatically and keeps all communications on this subject in this thread.
Web Site Host, Moderator Hiring Agent, Gas Appliances Topic Moderator, Multiple Forums Moderator & Natural Gas Appliance Diagnostics Technician.
Personal Driving Safety Reminder: Buckle Up & Drive Safely.
"The Life You Save, May Be Your Own."
Old 04-15-07, 09:45 PM
Received 3 Upvotes on 3 Posts
You may need an igniter replaced...are you able to take an amp read???
