Tappan Gas Oven
Old 04-16-07, 11:27 PM
Tappan Gas Oven
I just bought a house and it has an ancient tappan gas oven. The oven initially lights when turned on but goes off after a minute or so and wont come back on till cool. Any suggestions please.
Old 04-17-07, 07:25 AM
Sharp Advice's Avatar
Admin Emeritus
Received 5 Votes on 4 Posts
Arrow More Detailed Information Requested
Hello johnandmary and Welcome to the Do It Yourself Web Site and the Gas Appliances topic.
The professionals answering questions in this forum topic would be very pleased to help you. But first you need to help us.We need much more detailed and specific information. There could be any number of potential problems.
Detailed information about the problem or problems with the appliance helps to explain the situation your dealing with in a manner that allows myself and or several other professionals to offer the best possible helpful suggestions and advice.
Any and all additional detailed information you can provide may help to expose a clue regarding the current problem and help us to determine the exact solution to the problem.
Your assistance in this matter would be beneficial.
To add more information, please use the REPLY ****on.
Does the oven have a constant burning pilot flame?
Does the small constantly on pilot flame enlarge when the thermostat is turned on?
Does that larger flame heat an element?
Or.
Do you have to manually light the burner the first time the oven is turned on?
Use the reply ****on to add additional information. Using the reply ****on keeps or moves the topic back up to the top of the list automatically and keeps all communications on this subject in one thread.
Web Site Host, Moderator Hiring Agent, Gas Appliances Topic Moderator, Multiple Forums Moderator & Natural Gas Appliance Diagnostics Technician.
Personal Driving Safety Reminder: Buckle Up & Drive Safely.
"The Life You Save, May Be Your Own."
Old 04-17-07, 11:07 PM
Tappan Gas Oven
yes the pilot light stays on, as for the size or if it heats another element, i will have to check when i get home.
Old 04-18-07, 11:16 PM
Tappa Gas Oven
Pilot light stays on, burner lights, burns for a minute, then goes off.
Old 04-19-07, 08:32 AM
Admin Emeritus
Hello: johnandmary
One of two common causes.
The larger actuating flame is weak and not heating the safety element (bulb) enough. A weak flame is one that may appear yellow or slightly yellow(ed). In this case, blowing out the dust corrects the problem.
A weak larger flame (actuation flame) then becomes slightly distorted when the burner turns on, which then applies less heat to the safety element (bulb) and the burner then cycles off. Cleaning the entire pilot assembly often corrects the problem.
A can of compressed air works wonders to clean a pilot assembly. Same type of canned compressed air used to clean computer keyboards can be used. Insert extension tube into pilot assembly and blast out dust, etc.
Also do the same at the one or two holes slightly behind the pilot flame. Air holes will be in the tube that brings gas to the pilot just behind where the flame is located.
Be aware that cleaning may or may not resolve the condition. See below.
Be advised that warm air flow up wards from the burner, when the oven burner is on, can also cause the problem described. Remove all items and/or foils which may be in the oven and/or broiler compartments.
Second most common cause, if the above does not apply, is a weak element. That element is the bulb the larger flame heats. If heated correctly the safety element bulb may still be weak and or defective. Replacement is then required.
Retail parts dealers and appliances parts stores can also help determine what the possible problem may be based upon that specific brand and model. Bring the make, model and serial numbers. Dealers and appliances parts stores are listed in the phone book.
Cautionary Reminder Note:
Before attempting any repairs, be sure to unplug the appliance from the wall receptacle power source first.
Read The Sticky Help Note In This Topic:
Range-Stove-Oven-Broiler Basic Help Information & Manufacturers Web Sites. http://forum.doityourself.com/showthread.php?t=159808
Or copy and paste the below link into your browsers address bar. http://forum.doityourself.com/showthread.php?t=159808
Use the reply button to add additional information or questions. Using the reply button keeps or moves the topic back up to the top of the list automatically and keeps all communications on this subject in this thread.
Old 04-20-07, 01:35 AM
tappan gas oven
thank you for your help
