GE Oven will not stay hot
Old 05-23-07, 01:22 PM
T
I have a GE oven-Model JGBP30 and it will heat up to the temp set and then will not maintain that temp. The burners go off and only come back on if I hit the temp recal and start button. Any ideas?
Toby
Old 05-24-07, 02:25 PM
Sharp Advice's Avatar
Admin Emeritus
Received 7 Upvotes on 6 Posts
Hello Toby and Welcome to the Do It Yourself Web Site and to the Gas Appliances topic.
Common problem is often a weak HSI. (Hot Surface Igniter) Replacing the glow igniter likely to solve the problem. However, the gas control valve may also be the problem or part of the problem. Replacing both the HSI and the gas control valve at the same time very likely to resolve the problem.
Unless the problem is within the main computer control board. Not as likely as the HSI and Gas Valve. Suggestion would be to replace at least the HSI and note the results.
Read The Sticky Help Note In This Topic:
Range-Stove-Oven-Broiler Basic Help Information & Manufacturers Web Sites. http://forum.doityourself.com/showthread.php?t=159808
Or copy and paste the below link into your browsers address bar. http://forum.doityourself.com/showthread.php?t=159808
Retail parts dealers and appliances parts stores can also help determine what the possible problem may be based upon that specific brand and model. Bring the make, model and serial numbers. Dealers and appliances parts stores are listed in the phone book.
Cautionary Reminder Note:
Before attempting any repairs, be sure to unplug the appliance from the wall receptacle power source first.
Use the reply button to add additional information or questions. Using the reply button keeps or moves the topic back up to the top of the list automatically and keeps all communications on this subject in this thread.
Web Site Host, Moderator Hiring Agent, Gas Appliances Topic Moderator, Multiple Forums Moderator & Natural Gas Appliance Diagnostics Technician.
Personal Driving Safety Reminder: Buckle Up & Drive Safely.
"The Life You Save, May Be Your Own."
Old 05-24-07, 06:40 PM
T
Thanks for the reply,
My oven has two HSI, one for the broil and one for the bake, they are the same. I moved the broil one to the bake one and it works great. Now I have to order a new one to fix the broiler.
Toby
