Accessories for the Weber Baby Grill
Old 09-14-07, 10:36 AM
T
I just bought a slightly used Weber Q100 grill. It does not come with adapter hose or propane tank. Which adapter hose and propane tank (20 lb) would fit with the Q100? Do I need any other accessories? I would prefer buying used adapter hose & tank (probably at local swapmeet markets). Thanks.
Old 09-14-07, 01:41 PM
Sharp Advice's Avatar
Admin Emeritus
Received 7 Upvotes on 6 Posts
Hello: TruongKy. Welcome into the Gas Appliances topic.
No real way to determine exactly which adapter would fit properly without physically seeing the BBQ. Nor is it likely you'll find the correct one, if any, at any local swap meet markets. (Flea Markets, Yard sales, Garage sales) as they are sometimes called.
Best bet may be a local used RV repair shop or welding supply realer. Likely case is, you'll likely pay more for any used parts then the grill might be worth, without seeing the grill, etc.
Good Luck
Web Site Host, Forums Manager, Moderator Hiring and Promotions Agent, Gas Appliances Topic Moderator, Multiple Forums Moderator & Natural Gas Appliance Diagnostics Technician.
