Maytag gas cooktop, ignitors do not click
Old 09-24-07, 02:27 PM
T
Maytag MGS5536BDS, statinless steel gas cooktop,.
When I turn on the burners, the ignitors no longer click.
I can light the burner with a mtach. Any advice on how to diganose/fix the problem
Old 10-01-07, 05:09 AM
Sharp Advice's Avatar
Admin Emeritus
Received 5 Votes on 4 Posts
Hello tjohnson87. Welcome to the Gas Appliances topic and the Do-It-Yourself Web Site.
If there is electrical power to the appliance, the spark module may be defective or the fuse may be blown. Some spark modules have a fuse, which is located next to the module under the protective cover.
If the fuse visually appears to be okay it may not be. A continuity test would be required to determine it's condition. If the fuse needs to be replaced, use only an appliance fuse designed for the appliacation. All fuses are not the same or equal.
If the fuse is okay or there isn't one, the spark module may be defective or burned out. Removal and replacement is the only option. They are a non repairable item. Be sure to turn off or unplug the appliance before attempting any tests or repairs.
Additional Help Here:
Read the Range-Stove-Oven-Broiler Basic Help Informational Sticky Note, in this forums topic, for more detailed information.
Range-Stove-Oven-Broiler Basic Help Information, Fault Codes & Mfg's Web Site Links http://forum.doityourself.com/showthread.php?t=159808
Retail appliance parts dealers can also help determine what the possible problem may be also. They will need the make, model an serial numbers. Appliance parts dealers are an excellent source for original replacement parts. Dealers are listed in the phone book under appliances.
***If and or when you attempt any repairs, "Be sure the electrical power to the appliance is turned off, before attempting any repairs. Always check for gas leaks whenever the appliance is moved and/or a repair includes any connection of a gas part."
Kindly use the reply button to post all replies, add additional information or ask additional questions when replies are posted. Using this method moves and/or keeps the topic back up to the top of the list of questions automatically and keeps all content on the same subject within one thread.
Web Site Host, Gas Appliances Topic Moderator & Multiple Forums Moderator. Energy Conservation Consultant & Natural Gas Appliance Diagnostics and Repair Technician.
Personal Driving Safety Reminder:
Buckle Up & Drive Safely. "The Life You Save, May Be Your Own."
Old 10-11-07, 09:38 PM
B
Hey, I fixed my Maytag range top today! It has been months since we had a pro gas company guy say he couldn't fix it, said it needed a new ignition module, which he couldn't find (don't get that, guess they weren't that good)...anyway, I went online and found a parts place and a week later had a module that was an exact replacement...sooo, put it in today and guess what, didn't work! Still had no sparkie on top..so used a voltage tick (an inexpensive, audible, voltage indicator) to determine that voltage was leaving the controls on top but not arriving at the module down be the broiler drawer...turns out the wire running down the side between the cover and the oven was broken...it actually was broken inside the insulation and as I was wiggling it it broke and shorted against the side, popping the circuit breaker! So the better way to test that wire would be to turn off the power and test the continuity with a meter..anyway, be safe, and I'm glad I finally figured mine out..oh yeah, I haven't replaced the wire yet, I'll get it from an appliance guy, it's a special high-temperature wire...I did do a jury-rig test and it worked great.
