igniter question
Old 10-19-07, 04:42 PM
igniter question
I have a kitchen aid gas stove, when I turn on a burner all 4 igniters work but they keep going for about 5 minutes is this normal?
Old 10-21-07, 08:05 AM
Sharp Advice's Avatar
Admin Emeritus
Received 5 Votes on 4 Posts
Hello tyron. Welcome to the Gas Appliances topic and the Do-It-Yourself Web Site.
Problem description usually indicates one or more of the sparker's isn't being heated by the burner flames enough to signal the sparker module to stop sparking.
Cleaning the sparker's with a soft bristle brush or pipe cleaner usually works. Or one or more of the burners ports (holes in the burner head) isn't cleaned restricting the flames from impinging on the sparker. Cleaning out those ports usually resolves the problem.
Try one or both of the solutions above and post back the results. Also read the help sticky note here for additional information and help.
Retail appliance parts dealers can also help determine what the possible problem may be also. They will need the make, model an serial numbers. Appliance parts dealers are an excellent source for original replacement parts. Dealers are listed in the phone book under appliances.
***If and or when you attempt any repairs, "Be sure the electrical power to the appliance is turned off, before attempting any repairs. Always check for gas leaks whenever the appliance is moved and/or a repair includes any connection of a gas part."
Kindly use the reply button to post all replies, add additional information or ask additional questions when replies are posted. Using this method moves and/or keeps the topic back up to the top of the list of questions automatically and keeps all content on the same subject within one thread.
Web Site Host, Gas Appliances Topic Moderator & Multiple Forums Moderator. Energy Conservation Consultant & Natural Gas Appliance Diagnostics and Repair Technician.
Personal Driving Safety Reminder:
Buckle Up & Drive Safely. "The Life You Save, May Be Your Own."
Old 10-27-07, 03:11 PM
Thanks for the suggestion, I will give it a try
