from propane to gas switch back
Old 10-23-07, 07:10 PM
Question from propane to gas switch back
Hello, this is a GE Stove JGBS09PEH1WW 4burners, centergriddle, oven and no broiler. Flame is tiny it was set for propane.
Is a flame going to appear while set for propane?
And to switch back to NG (natural gas) need any new parts or I think I'm to switch over the burner tower and the piece with the whole in it (orifice? jet?) unscrew and turn upside down?
It does not appear complicated I just would like to know first before attempting because it is gas.
Thank You Very Much
Old 10-24-07, 08:44 AM
Sharp Advice's Avatar
Admin Emeritus
Received 7 Upvotes on 6 Posts
Hello seekknowledge. Welcome to the Gas Appliances topic and the Do-It-Yourself Web Site.
What has to be done is a conversion to propane from natural gas. Which means all the existing burner orifices have to be replaced with propane orifices. The oven temperature knob has to be pulled off and the set screw set to the NAT settings. And the appliance regulator has to be converted also.
Later model stoves have regulators that are convertible. It's simply a matter of turning over the tower cap on the regulator. Some appliance regulators have levers to change positions or set screws that have to be turned from one position to another. Look for the letter markings, "LP" or "Nat." Older stoves that do not have convertible regulators, the entire regulator must be replaced.
Additional Help Here:
Read the Range-Stove-Oven-Broiler Basic Help Informational Sticky Note, in this forums topic, for more detailed info.
Range-Stove-Oven-Broiler Basic Help Information, Fault Codes & Mfg's Web Site Links http://forum.doityourself.com/showthread.php?t=159808
Retail appliance parts dealers can also help determine what the possible problem may be also. They will need the make, model an serial numbers. Appliance parts dealers are an excellent source for original replacement parts. Dealers are listed in the phone book under appliances.
"Be sure the electrical power to the appliance is turned off, before attempting any repairs. Always check for gas leaks whenever the appliance is moved and/or a repair includes any connection of a gas part."
If you need further assistance, use the REPLY button. By doing so, the additional information you add or questions you may have, will remain within this posting. Using this method also moves the topic back up to the top of the list automatically.
Web Site Host, Gas Appliances Topic Moderator & Multiple Forums Moderator. Energy Conservation Consultant & Natural Gas Appliance Diagnostics and Repair Technician.
Personal Driving Safety Reminder:
Buckle Up & Drive Safely. "The Life You Save, May Be Your Own."
